Старый 25.05.2010, 09:05   #1
David Ferguson: Creating a report in X++ code and running
Источник: http://blogs.msdn.com/b/davidferguso...d-running.aspx
Here is a small job that demonstrates the main parts of build a report dynamically in X++ and launching it.
static void MakeReportJob(Args _args)
    #AOT
    str reportName = 'aaMakeReport';
    tableid custTableId = tablenum(CustTable);
    TreeNode reportNode = TreeNode::findNode(#ReportsPath);
    Report areport;
    ReportDesign design;
    ReportAutoDesignSpecs specs;
    ReportSection section;
    ReportRun run;
    // Delete the report if it already exists
    areport = reportNode.AOTfindChild(reportName);
    if (areport)
        areport.AOTdelete();
    // Build the report
    areport = reportNode.AOTadd(reportName);
    areport.query().addDataSource(custTableId);
    design = areport.addDesign('Design');
    specs = design.autoDesignSpecs();
    section = specs.addSection(ReportBlockType::Body, custTableId);
    section.addControl(custTableId, fieldnum(CustTable, AccountNum));
    section.addControl(custTableId, fieldnum(CustTable, Name));
    // Now the report will not prompt for user input
    areport.interactive(false);
    areport.query().interactive(false);
    areport.AOTcompile();
    run = ClassFactory.reportRunClass(new Args(reportName));
    run.init();
    run.run();
За это сообщение автора поблагодарили: AndyPanda (0).
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Microsoft Dynamics CRM Team Blog: Auditing Report Execution using the ReportServer Database Blog bot Dynamics CRM: Blogs 0 19.11.2008 20:05
axStart: Where is my code running Blog bot DAX Blogs 0 15.02.2008 16:40
Говорят вышел SP2 для Axapta 3. Кто нибуть что знает на эту тему? soin DAX: Прочие вопросы 10 13.10.2003 10:43
Часовой пояс GMT +3, время: 17:54.
