27.08.2021, 20:15 | #1 |
d365technext: Database sync failed during Dimension Activation
Источник: http://d365technext.blogspot.com/202...dimension.html
============== Database sync failed during Dimension Activation If you are facing the Database sync failure and below error while activating the Financial dimension in maintenance mode. Please perform the following steps to resolve this issue You need to fix your data. Go to the Visual studio find inventdim table then check what fields are in "DimIdx" index. Then Open the SQL and execute the below query to confirm either you have duplicate Invent Dim or nor select InventDimId from INVENTDIM group by InventDimId having count(*)>1 When records will be identified you need to make a decision on what to do with them. fix data or delete. Error Message Managed Data Sync Entity Worker encountered an exception, but is continuing because ContinueOnError is true. View Name and ID: Managed Data Sync Entity Worker encountered an exception, but is continuing because ContinueOnError is true. View Name and ID: 'DimensionCombinationEntity(5502)' Exception: System.InvalidOperationException: Database execution failed: Incorrect syntax near ')'. Incorrect syntax near ')'. CREATE VIEW [DBO].[DIMENSIONCOMBINATIONENTITY] AS SELECT T1.RECID AS RECORDID, T1.MAINACCOUNTVALUE AS MAINACCOUNT, T1.MODIFIEDDATETIME AS MODIFIEDDATETIME, T1.MODIFIEDBY AS MODIFIEDBY, T1.CREATEDDATETIME AS CREATEDDATETIME, T1.CREATEDBY AS CREATEDBY, T1.RECVERSION AS RECVERSION, T1.PARTITION AS PARTITION, T1.RECID AS RECID, T2.NAME AS ACCOUNTSTRUCTURE, T2.RECVERSION AS RECVERSION#2, T2.PARTITION AS PARTITION#2, T2.RECID AS RECID#2, (CAST (( SELECT ( REPLACE( REPLACE( REPLACE( CASE WHEN T1.LEDGERDIMENSIONTYPE != 1 THEN (SELECT CASE WHEN NonNullDisplayValue IS NOT NULL THEN NonNullDisplayValue ELSE 'No active format for data entities has been set up. Set up an active format for each dimension format type.' END FROM (SELECT ( -- Remove initial delimiter STUFF( (SELECT -- Prepend with delimiter and escape internal delimiters DIMENSIONSEGMENTDELIMITER + COALESCE( REPLACE(REPLACE(DIMLIST.COLUMNVALUE, '\', '\\'), DIMENSIONSEGMENTDELIMITER, DIMENSIONSEGMENTDELIMITERESCAPED), '') FROM -- Get the dimension hierarchy (SELECT TOP(1) DH.RECID FROM DIMENSIONHIERARCHY DH JOIN DIMENSIONHIERARCHYINTEGRATION DHI ON DHI.DIMENSIONHIERARCHY = DH.RECID AND DHI.ISDEFAULT = 1 AND DHI.PARTITION = T1.PARTITION WHERE DH.PARTITION = T1.PARTITION AND DH.STRUCTURETYPE = CASE T1.LEDGERDIMENSIONTYPE WHEN 0 THEN 18 WHEN 2 THEN 19 WHEN 4 THEN 20 END ) AS DH JOIN DIMENSIONHIERARCHYLEVEL DHL ON DHL.DIMENSIONHIERARCHY = DH.RECID AND DHL.PARTITION = T1.PARTITION JOIN DIMENSIONATTRIBUTE DA ON DA.RECID = DHL.DIMENSIONATTRIBUTE AND DA.PARTITION = T1.PARTITION LEFT JOIN (SELECT DIMENSIONATTRIBUTE, COLUMNVALUE FROM (SELECT * FROM DIMENSIONATTRIBUTEVALUECOMBINATION DAVC WHERE DAVC.PARTITION = T1.PARTITION AND DAVC.RECID = T1.RECID) P UNPIVOT (COLUMNVALUE for DIMENSIONATTRIBUTE IN (MAINACCOUNTVALUE)) AS DIMENSIONVALUECOLUMNNAME ) AS DIMLIST ON DIMLIST.DIMENSIONATTRIBUTE = REPLACE(DA.DIMENSIONVALUECOLUMNNAME COLLATE Database_Default, '.', '$') ORDER BY DHL.DIMENSIONHIERARCHY, DHL.LEVEL_ FOR XML PATH('') ), 1, LEN(DIMENSIONSEGMENTDELIMITER), '') ) AS NonNullDisplayValue) AS DisplayValueFormat) ELSE -- Default or dynamic accounts (SELECT REPLACE(REPLACE(T1.DISPLAYVALUE, '\', '\\'), DIMENSIONSEGMENTDELIMITER, DIMENSIONSEGMENTDELIMITERESCAPED)) END , '&', '&') , '<', '') ) FROM (SELECT TOP(1) --Determine the segment delimiter CASE DIMENSIONSEGMENTDELIMITER WHEN 0 THEN '-' WHEN 1 THEN '.' WHEN 2 THEN '_' WHEN 3 THEN '|' WHEN 7 THEN '||' WHEN 8 THEN '~' WHEN 4 THEN '--' WHEN 5 THEN '..' WHEN 6 THEN '__' WHEN 9 THEN '~~' END AS DIMENSIONSEGMENTDELIMITER, --Determine the account delimiter escaped WHEN 0 THEN '\-' WHEN 1 THEN '\.' WHEN 2 THEN '\_' WHEN 3 THEN '\|' WHEN 7 THEN '\|\|' WHEN 8 THEN '\~' WHEN 4 THEN '\-\-' WHEN 5 THEN '\.\.' WHEN 6 THEN '\_\_' WHEN 9 THEN '\~\~' END AS DIMENSIONSEGMENTDELIMITERESCAPED FROM DIMENSIONPARAMETERS WHERE DIMENSIONPARAMETERS.PARTITION = T1.PARTITION ) AS DIMENSIONPARAMETERS ) AS NVARCHAR(500))) AS DISPLAYVALUE, (CAST ((T1.DISPLAYVALUE) AS NVARCHAR(30))) AS ACCOUNTVALUE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS BANKACCOUNTID, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS CLIENTORGANIZATIONUNIT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS DELIVERYCHANNEL, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS FINALCLIENT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS INTERCOMPANY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSKILLSET, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBINDUSTRY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBSERVICELINE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PL_PODATEK, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PROGRAMWBS, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS VENDORLEGALENTITY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALCOSTCENTER FROM DIMENSIONATTRIBUTEVALUECOMBINATION T1 LEFT OUTER JOIN DIMENSIONHIERARCHY T2 ON(( T1.ACCOUNTSTRUCTURE = T2.RECID) AND ( T1.PARTITION = T2.PARTITION)) ---> System.Data.SqlClient.SqlException: ) AS NVARCHAR(500))) AS DISPLAYVALUE, (CAST ((T1.DISPLAYVALUE) AS NVARCHAR(30))) AS ACCOUNTVALUE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS BANKACCOUNTID, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS CLIENTORGANIZATIONUNIT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS DELIVERYCHANNEL, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS FINALCLIENT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS INTERCOMPANY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSKILLSET, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBINDUSTRY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBSERVICELINE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PL_PODATEK, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PROGRAMWBS, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS VENDORLEGALENTITY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALCOSTCENTER FROM DIMENSIONATTRIBUTEVALUECOMBINATION T1 LEFT OUTER JOIN DIMENSIONHIERARCHY T2 ON(( T1.ACCOUNTSTRUCTURE = T2.RECID) AND ( T1.PARTITION = T2.PARTITION)) ---> System.Data.SqlClient.SqlException: Incorrect syntax near ')'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Microsoft.Practices.EnterpriseLibrary.TransientFaultHandling.SqlCommandExtensions.c__DisplayClass1.b__0() at Microsoft.Practices.EnterpriseLibrary.TransientFaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func) at Microsoft.Dynamics.AX.Data.Sql.SqlDataAccessManager.b__30_0(SqlCommand c) at Microsoft.Dynamics.AX.Data.Sql.SqlDataAccessManager.ExecuteSql[T](SqlCommand cmd, Func`2 sqlFunc) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Microsoft.Dynamics.AX.Data.Sql.SqlDataAccessManager.HandleException(ExceptionDispatchInfo edi, SqlExecutionInfo execInfo) at Microsoft.Dynamics.AX.Data.Management.DBExecute.ExecuteDDLWithNewTransaction(IEnumerable`1 commandTextInBatch) --- End of inner exception stack trace --- at Microsoft.Dynamics.AX.Data.Management.DBExecute.ThrowOnSqlExecuteException(SqlException e, String commandText) at Microsoft.Dynamics.AX.Data.Management.DataEntity.ManagedSyncDataEntityWorker.SyncAllAction[T](ViewSyncGraphNode viewToSync, Dictionary`2 oldViewDefinitions, StringCollection dataEntityViewList, StringCollection compositeEntityViewList, IProducerConsumerCollection`1 modifiedViewDependencies) at Microsoft.Dynamics.AX.Data.Management.DataEntity.ManagedSyncDataEntityWorker.DoSyncAll[T](IEnumerable`1 sortedViewList, Dictionary`2 oldViewDefinitions, IProducerConsumerCollection`1 modifiedViewDependencies) AOS database sync failed. Microsoft.Dynamics.AX.Framework.Database.TableSyncException: AOS database sync failed. Microsoft.Dynamics.AX.Framework.Database.TableSyncException: Full sync did not complete successfully. Error: AggregateException:One or more errors occurred. at Microsoft.Dynamics.AX.Data.Management.ManagedSyncWorkerManager.SyncAll() at Microsoft.Dynamics.AX.Data.Management.ManagedSync.b__21_0() at Microsoft.Dynamics.AX.Data.Management.ManagedSync.EnsureMetadataProviderCacheCleared(Action action) at Microsoft.Dynamics.AX.Data.Management.ManagedSync.SyncAll() at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.RunFullManagedSync(SyncOptions options, String sqlConnectionString, IMetadataProvider metadataProvider) at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.c__DisplayClass20_0.b__0() at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.ExecuteWithinAOS(SyncOptions syncOptions, String sqlConnectionString, IMetadataProvider metadataProvider, Func`1 func, Action`1 errorHandler) Inner exceptions: Database execution failed: Database execution failed: Incorrect syntax near ')'. ) AS NVARCHAR(500))) AS DISPLAYVALUE, (CAST ((T1.DISPLAYVALUE) AS NVARCHAR(30))) AS ACCOUNTVALUE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS BANKACCOUNTID, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS CLIENTORGANIZATIONUNIT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS DELIVERYCHANNEL, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS FINALCLIENT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS INTERCOMPANY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSKILLSET, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBINDUSTRY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBSERVICELINE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PL_PODATEK, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PROGRAMWBS, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS VENDORLEGALENTITY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALCOSTCENTER FROM DIMENSIONATTRIBUTEVALUECOMBINATION T1 LEFT OUTER JOIN DIMENSIONHIERARCHY T2 ON(( T1.ACCOUNTSTRUCTURE = T2.RECID) AND ( T1.PARTITION = T2.PARTITION)) at Microsoft.Dynamics.AX.Data.Management.DataEntity.ManagedSyncDataEntityWorker.DoSyncAll[T](IEnumerable`1 sortedViewList, Dictionary`2 oldViewDefinitions, IProducerConsumerCollection`1 modifiedViewDependencies). at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.c.b__20_1(Tuple`2 result) at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.RunFullTableSync(SyncOptions syncOptions, String sqlConnectionString, IMetadataProvider metadataProvider) at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.FullTableViewSync() at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.FullSync() at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.RunSync() at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.Run(String metadataDirectory, String sqlConnectionString, SyncOptions options) Process: syncengine.exe exited with code -1. Источник: http://d365technext.blogspot.com/202...dimension.html
