18.08.2021, 17:11 | #1 |
d365technext: The 'Dimension Legal Entity Context field' must be entered
Источник: http://d365technext.blogspot.com/202...y-context.html
============== The 'Dimension Legal Entity Context field' must be entered, when the extended data type is 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount'. Today, I was getting the following errors while creating one data entity, after searching over google I realized that two field-level properties on my entity should be filled.
Path: [AxDataEntityView/ABCDEntity/Fields/LedgerDimension/DimensionLegalEntityContextField]:The 'Dimension Legal Entity Context field' must be entered, when the extended data type is 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount'.Path: [AxDataEntityView/ABCDEntity/Fields/LedgerDimension/DynamicDimensionEnumerationField]:The 'Dynamic Dimension Enumeration Field' must be entered, when the extended data type is 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount'. Solution DimensionLegalEntityContextField This field property should be filled with Data Area Id, for reference, I also pasted the screenshot. DynamicDimensionEnumerationField This field property should be filled with either 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount for reference, I also pasted the screenshot. Options:
