19.03.2023, 23:13 | #1 |
daxrunbase: DMF TransferStatus to check entity processing
Источник: https://www.daxrunbase.com/2023/03/1...ty-processing/
============== When we work with a Data Entity in D365FO, it can get tricky to track how transfers are going and how much is left. Here is a quick SQL snippet to query staging tables to figure out DMF TransferStatus: select executionid, transferstatus, case when transferstatus = 0 then 'Not started' when transferstatus = 1 then [...] The post DMF TransferStatus to check entity processing appeared first on DAXRunBase. Источник: https://www.daxrunbase.com/2023/03/1...ty-processing/
