04.04.2022, 01:03 | #1 |
How to change currency symbol in a given number format
Источник: http://alexvoy.blogspot.com/2022/04/...-in-given.html
============== Say, we need to print a Vendor payment advice in the vendor's language, whic is es (Spanish) in the example below. Once the report parameter AX_RenderingCulture is set to 'es', all related number formatting will be applied to amounts cells. However, the payment may be made in different currencies; thus its currency symbol $ must be used instead of Euro. Basically, such parameters, like currency symbol etc, can be changed through System.Globalization.CultureInfo class created for the rendering culture. I did not find a way how to achieve it for a particular textbox in SSRS design. So, I formatted the amount directly in X++. I used Global::strFmtByLanguage method as a basis for my method to replace the culture number format currency symbol to a given one. There are a few other interesting methods you can check to see how to deal with formatting dates and numbers. /// /// Replaces language rendering culture currency symbol with the given one /// /// language rendering culture /// AmountCur /// New currency symbol /// Formatted string public str eogChangeCurSymbolForAmountStr(LanguageId _languageId, System.Double _amountCur, CurrencySymbol _currencySymbol) { System.Globalization.CultureInfo culture; str res; System.Exception e; str curSymbol; culture = new System.Globalization.CultureInfo(_languageId); try { res = _amountCur.ToString("C", culture); curSymbol = culture.NumberFormat.CurrencySymbol; res = strReplace(res, curSymbol, _currencySymbol); } catch(Exception::CLRError) { e = CLRInterop::getLastException(); while( e ) { error( e.get_Message() ); e = e.get_InnerException(); } throw Exception::Error; } return res; } /// /// Gets amount with currency symbol /// /// Amount in currency /// Currency to present symbol /// Language for rendering culture /// Formatted string for amunt cur with currency symbol public EOGAmountStringWithCurrencySymbol eogAmountStringWithCurrencySymbol(AmountCur _amountCur, CurrencyCode _currency, LanguageId _languageId) { Currency currency = Currency::find(_currency); return this.eogChangeCurSymbolForAmountStr(_languageId, _amountCur, currency.Symbol);; } /// /// Populates BankPaymAdviceVendTmp and inserts the report information for a single invoice and related payment. /// protected void insertBankPaymAdviceTmp() { BankPaymAdviceVendTmp bankPaymAdviceVendTmp; str email; next insertBankPaymAdviceTmp(); bankPaymAdviceVendTmp = this.bankPaymAdviceTmp as BankPaymAdviceVendTmp; if (bankPaymAdviceVendTmp.RecId) { ttsbegin; bankPaymAdviceVendTmp.selectForUpdate(true); bankPaymAdviceVendTmp.EOGBalance01Total+=bankPaymAdviceVendTmp.Balance01; bankPaymAdviceVendTmp.EOGAmountStringWithCurrencySymbol = this.eogAmountStringWithCurrencySymbol(bankPaymAdviceVendTmp.EOGBalance01Total, bankPaymAdviceVendTmp.CurrencyCode, VendTable::find(bankPaymAdviceVendTmp.AccountNum).languageId()); bankPaymAdviceVendTmp.update(); ttscommit; } } The final string can be referenced in Total textbox as Last(bankPaymAdviceVendTmp.EOGAmountStringWithCurrencySymbol) and with default format. Источник: http://alexvoy.blogspot.com/2022/04/...-in-given.html
