Старый 07.05.2021, 10:11   #1
25,475 / 846 (79) +++++++
goshoom: Entity metadata in a console application
Источник: http://dev.goshoom.net/2021/05/entit...e-application/
There was a question in the Community forum about creating tables in an external databases that would match the schema of F&O data entities.
One of the possible approaches is generating SQL code for CREATE TABLE statement. The information about field names, types and such things would be taken from F&O metadata and we already have a nice API for this purpose.
Here is code for simple console application getting some of the necessary data:
using System;using System.Collections.Generic;using System.Linq;using Microsoft.Dynamics.AX.Metadata.MetaModel;using Microsoft.Dynamics.AX.Metadata.Storage;using Microsoft.Dynamics.AX.Metadata.Storage.Runtime; namespace DataEntityFields{ public class Demo { public static void Main(string[] args) { var environment = Microsoft.Dynamics.ApplicationPlatform.Environment.EnvironmentFactory.GetApplicationEnvironment(); var runtimeConfiguration = new RuntimeProviderConfiguration(environment.Aos.PackageDirectory); var metadataProvider = new MetadataProviderFactory().CreateRuntimeProviderWithExtensions(runtimeConfiguration); AxDataEntityView entity = metadataProvider.DataEntityViews.Read("VendVendorV2Entity"); foreach (AxDataEntityViewMappedField entityField in entity.Fields.Where(f => f is AxDataEntityViewMappedField)) { var datasource = FindDataSource(entity.ViewMetadata.DataSources, entityField.DataSource); if (datasource == null) { continue; } AxTable table = metadataProvider.Tables.Read(datasource.Table); AxTableField field = table.Fields[entityField.DataField]; AxTableFieldString stringField = field as AxTableFieldString; if (stringField != null) { Console.WriteLine($"{entityField.Name} (String {stringField.StringSize})"); } } Console.ReadLine(); } private static AxQuerySimpleDataSource FindDataSource(IEnumerable dataSources, string dataSourceName) { foreach (AxQuerySimpleDataSource ds in dataSources) { if (ds.Name == dataSourceName) { return ds; } return FindDataSource(ds.DataSources, dataSourceName); } return null; } }}
Note that it requires references to a few assemblies:
  • Microsoft.Dynamics.AX.Metadata.dll
  • Microsoft.Dynamics.AX.Metadata.Core.dll
  • Microsoft.Dynamics.AX.Metadata.Storage.dll
  • Microsoft.Dynamics.ApplicationPlatform.Environment.dll
dynamicsaxinsight: AX7/D365/Operations: Create customer postal address through data entity from .NET console application Blog bot DAX Blogs 0 20.09.2017 15:11
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 5.0 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:51
Права на добавление объектов в Дизайнере Cyr NAV: Администрирование 10 13.06.2009 21:27
Часовой пояс GMT +3, время: 06:50.
