04.11.2011, 17:12 | #1 |
palleagermark: Call a BOF service with a caller record
Источник: http://palleagermark.blogspot.com/20...er-record.html
============== If you need to call a Business Operations Framework (BOF) service with a caller record, like you'd often do for a RunBase job, you must create a custom SysOperationServiceController to get the record argument passes from the service controller to an applicable data contract. A good example from standard AX can found in the PurchFinalizeServiceController class. Another example can be found here: http://www.artofcreation.be/2011/08/...icecontroller/ Источник: http://palleagermark.blogspot.com/20...er-record.html
