Старый 10.09.2021, 19:13   #1
25,475 / 846 (79) +++++++
d365technext: Configuration key & Security Key
Источник: https://d365technext.blogspot.com/20...ionkeySecurity Key.html
Why do we provide Configuration key & Security Key?
Configuration key: Configuration keys allow administrators to enable or disable features in the application for all users. Disabling features help to minimize the attack surface against potential attacks.
Configuration keys are applied to:
  1. Tables
  2. Fields
  3. Indexes
  5. Menus
  6. Menu items
  7. Form controls,
  8. Report controls
  9. Extended data types
  10. Enumerations
Security key: Security keys allow administrators to set security on a user group level. Minimizing access on a user group level helps to reduce the attack surface against potential attacks.
The main reasons to apply user-level security are to:
Allow users to do only their designated tasks.
Protect sensitive data in the database.
Prevent users from inadvertently breaking an application by changing code or objects on which the application depends.
You need to apply a security key to:
· Tables
· Views
· Menus
· Menu items
· Form controls
· Report controls
ax-erp: Choosing a Primary Key: Natural or Surrogate? Blog bot DAX Blogs 0 18.12.2012 02:11
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 23:13.
