Старый 27.07.2021, 11:11   #1
25,475 / 846 (79) +++++++
ariste.info: Dual-write table mappings: copy to other environments
Источник: https://ariste.info/en/2021/07/dual-...-environments/
In a past post, we learned how to create custom data entities to be used in Dual-write. And now you might be asking yourself, how do I move the Dual-write table mappings to a test or production environment from the development environment? Do I need to repeat everything I’ve done on the dev machine in [...]
ariste.info Dual-write table mappings: copy to other environments
ariste.info: Self-service & SSRS: print reports as PDF in your Dev VM Blog bot DAX Blogs 0 21.07.2020 16:16
ariste.info: Azure hosted build for Dynamics 365 Finance & SCM Blog bot DAX Blogs 0 01.05.2020 13:11
ariste.info: LCS DB API: automating Prod to Dev DB copies Blog bot DAX Blogs 0 21.04.2020 11:11
Kine’s info: Copy Microsoft Dynamics NAV company by SQL script into another database Blog bot NAV: Blogs 0 15.05.2016 17:11
Часовой пояс GMT +3, время: 18:39.
