22.07.2016, 22:13 | #1 |
organicax: Catalog doesn’t show hierarchy for new call center
Источник: https://organicax.com/2016/07/22/cat...w-call-center/
============== If you are trying to setup a new call center and a related catalog, if the catalog doesn’t display a hierarchy the likely you have missed setting up the retail store product attributes. There is a parameter in the attributes called category hierarchy that you will need to assign. Here is a quick overview. AX2012 R3 CU10. Just as a reminder you won’t be able to setup the store product attributes unless you have associated the channel to an organization hierarchy. See this post. Cheers Lachlan Filed under: Retail Источник: https://organicax.com/2016/07/22/cat...w-call-center/
