18.07.2012, 19:11 | #1 |
emeadaxsupport: Slow POS when no internet connectivity
Источник: http://blogs.msdn.com/b/axsupport/ar...nectivity.aspx
============== Description: When starting the POS it takes several minutes to launch. We traced this behavior with Netmon and saw that POS called unsuccessful VeriSign and Akamai. This caused a delay in the POS startup. Cause: It is standard security behavior for Authenticode signed .NET applications to try and verify the certificate authority. In the case of non-Internet connected machines this could cause this behavior as it will time out trying to connect to the server. Solutions: 1. First solution is to disable the publishers certificate revocation, but this solution disables it for the whole computer. Internet Explorer > Tools > Advanced > Check for publishers certificate revocation. 2. Second solution is to modify the Pos.Exe.Config file found in the POS directory,by adding the following XML string Note: The generatePublisherEvidence was introduced in .Net framwork 2.0. POS is compiled in :net framework 3.5 and therefore the key works there as well. http://support.microsoft.com/kb/936707/en-us?fr=1 Author: Kim Truelsen Date: 18/7-2012 Источник: http://blogs.msdn.com/b/axsupport/ar...nectivity.aspx
