12.11.2021, 20:13 | #1 |
d365technext: Data Management Project Using X++
Источник: https://d365technext.blogspot.com/20...t-using-x.html
============== Data Management Project Using X++ Using the following code, you can import the file and execute the project using your x++ code. In the code, I am making the file on runtime and uploading the file into temp storage for the demo purpose but you can use the file uploader as per your requirement. Code class AD_Test { /// /// Runs the class with the specified arguments. /// /// The specified arguments. public static void main(Args _args) { FileUploadTemporaryStorageStrategy fileUploadStrategyInstance; DMFDefinitionGroupEntity definitionGroupEntityBuffer; DMFEntity dmfEntitybuffer; FileUploadTemporaryStorageResult result; SysDictClass uploadStrategyDictClassInstance; str entityName = 'VendVendorGroupEntity'; System.IO.StreamWriter swriter; System.IO.MemoryStream fileStream; DMFExecutionId executionId; #File fileStream = new System.IO.MemoryStream(); swriter = new System.IO.StreamWriter(fileStream); swriter.WriteLine("VENDORGROUPID,DESCRIPTION"); swriter.WriteLine(strFmt("%1,%2",'Ex-VendGroup','Example Vendor group')); swriter.Flush(); uploadStrategyDictClassInstance = new SysDictClass(className2Id('FileUploadTemporaryStorageStrategy')); fileUploadStrategyInstance = uploadStrategyDictClassInstance.makeObject() as FileUploadTemporaryStorageStrategy; result = fileUploadStrategyInstance.uploadFile(fileStream, 'VendorsGroups.csv'); fileStream.Dispose(); CodeAccessPermission::revertAssert(); executionId = DMFUtil::setupNewExecution('ImportVendorGroup'); select firstonly Entity from definitionGroupEntityBuffer exists join dmfEntitybuffer where definitionGroupEntityBuffer.DefinitionGroup == 'ImportVendorGroup' && dmfEntitybuffer.EntityName == definitionGroupEntityBuffer.Entity && dmfEntitybuffer.TargetEntity == entityName ; DMFDefinitionGroupExecution executionBuffer = DMFDefinitionGroupExecution::find('ImportVendorGroup', definitionGroupEntityBuffer.Entity, executionId, true); ttsbegin; executionBuffer.FilePath = result.getFileId(); executionBuffer.IsTransformed = NoYes::Yes; executionBuffer.update(); ttscommit; DMFQuickImportExport::doPGImport('ImportVendorGroup', executionId, true); } } Источник: https://d365technext.blogspot.com/20...t-using-x.html
Опции темы | Поиск в этой теме |
Опции просмотра | |
