Старый 10.09.2021, 04:44   #1
25,475 / 846 (79) +++++++
d365technext: Concept of extensions
Источник: https://d365technext.blogspot.com/20...ionD365FO.html
Define Concept of Extensions
An extension is a way to add functionality to an object in D365FO without modifying the base code of that object.
Your extensions are compiled into their own DLLs, which are separate from the D365 base system libraries. It also makes it easier for Microsoft to patch their sys layer code.
Microsoft has added to allow customizations without allowing the base code to be changed because they plan to not allow any overlaying of SYS layer code.
Here are my old articles
Class Extension
Lable Extension
Form Extension
Display Method using Extension
Lookup Extension
CDX Extension
daxmusings: The Overall Concept of Extensions in AX 7 Blog bot DAX Blogs 0 14.09.2017 13:11
waldo: Microsoft Dynamics NAV Extensions – Concerns (2/3) Blog bot NAV: Blogs 0 19.10.2016 04:25
daxmusings: The Overall Concept of Extensions in AX 7 Blog bot DAX Blogs 0 04.10.2016 12:11
Microsoft Dynamics CRM Team Blog: Convergence 2011 Concept Box Invitation Blog bot Dynamics CRM: Blogs 0 16.03.2011 19:11
dynamicsmatters: The concept of Warehouse and extensions Blog bot DAX Blogs 0 23.12.2006 02:16
Часовой пояс GMT +3, время: 14:19.
