Старый 31.08.2024, 03:46   #1
Dual-write setup from Lifecycle Services fails at Application step
Источник: http://alexvoy.blogspot.com/2024/08/...lifecycle.html
If you receive the issue with applying Dual-write for your D365FO environment following the standard procedure, you may need just to change one database parameter.
Open SQL MS and switch this flip to True and keep default values for your database.
Now you can resume the process.
stoneridgesoftware: How to Refresh Dynamics 365 Finance and Operations UAT with Dual Write from PROD Blog bot DAX Blogs 0 15.12.2023 04:46
gustafwesterlund: Quickfind bug in 9.1.0.643 Blog bot Dynamics CRM: Blogs 0 21.11.2018 14:11
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
dynamics-community.at: Online Trainingsvideos für Dynamics AX Lifecycle Services Blog bot DAX auf Deutsch 0 18.09.2013 17:11
Freddys: Connecting to NAV Web Services from the Cloud–Part 1 out of 5 Blog bot Dynamics CRM: Blogs 0 01.12.2010 02:59
Часовой пояс GMT +3, время: 21:03.
