Старый 29.02.2024, 09:13   #4
dech is offline
dech
Аватар для dech
Самостоятельные клиенты AX
650 / 352 (13) ++++++
Там еще идет функция вдовесок. В принципе не сложная, думаю.
PHP код:
CREATE FUNCTION [dbo].[PPOPeekValue](@FieldId INT, @FieldType TINYINT, @Data VARBINARY(MAX), @Position BIGINTRETURNS NVARCHAR(MAX)
AS
BEGIN
DECLARE @Result        NVARCHAR(MAX)
N            INT
, @IntValue    INT
, @Exp        INT
, @Sign        INT
, @FloatValue    FLOAT
, @Year        INT
, @Month        TINYINT
, @Day        TINYINT
, @BigValue    BIGINT
-- decode string/text values
IF @FieldType OR @FieldType 8
    BEGIN
        SET
@0
WHILE CAST(SUBSTRING(@Data, @Position + @N2) AS SMALLINT) <> 0
            SET
@= @2
        SET
@Result CAST(SUBSTRING(@Data, @Position, @N) AS NVARCHAR(MAX))
END ELSE
decode integer/time values
IF @FieldType 1
    BEGIN
        SET
@IntValue 0
        SET
@3
WHILE @>= 0
        BEGIN
            SET
@IntValue = @IntValue 256 ASCII(SUBSTRING(@Data, @Position + @N1))
SET @= @1
        END
IF @FieldId 61441 OR @FieldId 61445
        BEGIN
            SET
@Result CAST(dbo.PPOInt2Time(@IntValue) AS NVARCHAR(MAX));
END
ELSE
SET @Result CAST(@IntValue AS NVARCHAR(MAX))
END ELSE
decode float values
IF @FieldType 2
      BEGIN
        SET
@9
        SET
@FloatValue 0;
        WHILE @
1
        BEGIN
            SET
@Exp ASCII(SUBSTRING(@Data, @Position + @N1))
SET @FloatValue 100 * @FloatValue + (@Exp 0xF0) / 16 10 + (@Exp 0x0F)
SET @= @1
        END
        SET
@Sign = CASE WHEN ASCII(SUBSTRING(@Data, @Position 11)) & 0x80 0 THEN 1 ELSE -1 END
        SET
@Exp ASCII(SUBSTRING(@Data, @Position1))
        IF (@
Exp >= 0x80)
SET @Exp = @Exp 0x100
        SET
@FloatValue = @FloatValue * @Sign POWER(CAST(10 AS FLOAT), @Exp 15)
SET @Result CAST(STR(@FloatValue163) AS NVARCHAR(MAX))
END ELSE
decode date values
IF @FieldType 3
    BEGIN
        SET
@Year   1900 ASCII(SUBSTRING(@Data, @Position1))
SET @Month  =    ASCII(SUBSTRING(@Data, @Position 11))
SET @Day    =    ASCII(SUBSTRING(@Data, @Position 21))
SET @Result CAST(@Month AS VARCHAR(2)) + '/' CAST(@Day AS VARCHAR(2)) + '/' CAST(@Year AS VARCHAR(4))
END ELSE
decode enum values
IF @FieldType 4
    BEGIN
        SET
@ASCII(SUBSTRING(@Data, @Position1))
SET @IntValue ASCII(SUBSTRING(@Data, @Position+11)) + 256 ASCII(SUBSTRING(@Data, @Position+21))
SELECT @Result EnumItemLabel FROM SRSAnalysisEnums AS [AE]
WHERE [AE].EnumId = @IntValue
AND [AE].EnumItemValue = @N
    END
ELSE
decode int64 values
IF @FieldType 49
    BEGIN
        SET
@BigValue 0
        SET
@7
WHILE @>= 0
        BEGIN
            SET
@BigValue = @BigValue 256 ASCII(SUBSTRING(@Data, @Position + @N1))
SET @= @1
        END
        SET
@Result CAST(@BigValue AS VARCHAR(MAX))
END
RETURN @Result
END
// no comments
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1A [Introduction and SQL Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Dynamics AX: SQL Sever 2008 - Performance with Dynamics AX 2009 - Resource Governor Blog bot DAX Blogs 0 23.01.2009 22:05
Часовой пояс GMT +3, время: 13:05.
