Старый 08.06.2022, 09:48   #1
DarkSpirit22 is offline
DarkSpirit22
Аватар для DarkSpirit22
13 / 94 (4) ++++
Я сделал axapta-vs-c# проект WebRequestNet с оберткой:
using System;
using System.Net;
namespace WebRequestNet
    public class HttpWebRequestExceptionSafe
        public HttpWebRequest HttpWebRequest { get; private set; }
        protected HttpWebRequestExceptionSafe(HttpWebRequest _httpWebRequest)
            this.HttpWebRequest = _httpWebRequest;
        public static HttpWebRequestExceptionSafe Create(Uri requestUri)
            return new HttpWebRequestExceptionSafe((HttpWebRequest)HttpWebRequest.Create(requestUri));
        public static HttpWebRequestExceptionSafe Create(string requestUriString)
            return new HttpWebRequestExceptionSafe((HttpWebRequest)HttpWebRequest.Create(requestUriString));
        public HttpWebResponse GetResponseSafe()
            try
                return this.HttpWebRequest.GetResponse() as HttpWebResponse;
            catch (WebException ex)
                HttpWebResponse response = ex.Response as System.Net.HttpWebResponse;
                if (response == null)
                    throw;
                return response;
И на примере метода RetailCommonWebAPI.getResponse это будет выглядеть так:
/// <summary>
/// Get retail web access request.
/// </summary>
/// <param name="_request">
/// Retail web request.
/// </param>
/// <returns>
/// Web response to access.
/// </returns>
public RetailWebResponse getResponse(RetailWebRequest _request)
    System.Net.HttpWebRequest       request = null;
    System.Net.HttpWebResponse      response = null;
    CLRObject                       webResponse;
    System.Net.WebHeaderCollection  headers;
    System.IO.MemoryStream          stream;
    Binary                          requestContent;
    str                             responseData;
    System.Exception                ex;
    System.Net.WebException         webException;
    RetailWebResponse               retailWebResponse;
    int                             httpStatusCode;
    str                             contentType;
    MapEnumerator                   headerMapEnumerator;
        //+ Abramov_ 26.04.2022 TSK0000262_02
    WebRequestNet.HttpWebRequestExceptionSafe requestAdapter;
    str                                       exceptionMessage;
    System.Exception                          innerException;
    System.Net.WebExceptionStatus             webExceptionStatus;
    //- Abramov_ 26.04.2022 TSK0000262_02
    try
        //+ Abramov_ 20.04.2022 TSK0000262_02
        //request = System.Net.WebRequest::Create(_request.parmUrl()) as System.Net.HttpWebRequest;
        requestAdapter = WebRequestNet.HttpWebRequestExceptionSafe::Create(_request.parmUrl());
        request        = requestAdapter.get_HttpWebRequest();
        //- Abramov_ 20.04.2022 TSK0000262_02
        if (strLen(_request.parmMethod()) > 0)
            request.set_Method(_request.parmMethod());
        headers = request.get_Headers();
        //+ Abramov_ 19.11.2021 TSK0000009_01
        if (strLen(_request.parmHeader()) > 0)
            headers.Add(_request.parmHeader());
        headerMapEnumerator = _request.getHeaders().getEnumerator();
        while (headerMapEnumerator.moveNext())
            headers.Add(any2str(headerMapEnumerator.currentKey()), any2str(headerMapEnumerator.currentValue()));
        //- Abramov_ 19.11.2021 TSK0000009_01
        if (strLen(_request.parmContentType()) > 0)
            request.set_ContentType(_request.parmContentType());
        requestContent = _request.parmContent();
        if (requestContent)
            stream = requestContent.getMemoryStream();
            RetailCommonWebAPI::writeRequestData(request, stream.ToArray());
        if (_request.parmKeepAlive())
            request.set_KeepAlive(CLRInterop::getObjectForAnyType(_request.parmKeepAlive()));
        //+ Abramov_ 25.04.2022 TSK0000264_01
        if (_request.parmTimeout())
            request.set_Timeout(_request.parmTimeout());
        //- Abramov_ 25.04.2022 TSK0000264_01
        // Вызов "безопасной" версии метода GetResponse, который не генерирует исключение при получении ответа от сервера, но с кодом отличным от 200.
        webResponse = request.GetResponse();
        response = webResponse as System.Net.HttpWebResponse;
        response = requestAdapter.GetResponseSafe();
    catch (Exception::CLRError)
        ex = ClrInterop::getLastException();
        if (ex != null && ex.get_InnerException() != null)
            innerException = ex.get_InnerException();
            if (innerException is System.Net.WebException)
                webException = innerException as System.Net.WebException;
                //Обработка случая, когда Response "сидит" в WebException, находится в методе requestAdapter.GetResponseSafe();
                webExceptionStatus = webException.get_Status();
                if (webExceptionStatus == System.Net.WebExceptionStatus::Timeout)
                    error(innerException.get_Message());
                    throw Exception::Timeout;
                else
                        throw error(innerException.get_Message());
        while (innerException)
            // BP deviation documented
            if (exceptionMessage)
                exceptionMessage += '\n';
            exceptionMessage += exceptionMessage + " " + CLRInterop::getAnyTypeForObject(innerException.get_Message());
            innerException = innerException.get_InnerException();
        throw error(exceptionMessage);
    responseData = RetailCommonWebAPI::readResponseData(response);
    response.Close();
    httpStatusCode = response.get_StatusCode();
    contentType = response.get_ContentType();
    retailWebResponse = new RetailWebResponse(httpStatusCode, responseData, contentType);
    return retailWebResponse;
emeadaxsupport: EHF – eInvoice for Norway – DAX 2012 – setup Reviewed 31012016 Blog bot DAX Blogs 0 22.02.2016 17:11
ChangeCompany Try...Catch Владимир Максимов DAX: Программирование 10 12.01.2009 17:19
Глупый вопрос про try .. catch Vadik DAX: База знаний и проекты 6 12.03.2003 18:04
Часовой пояс GMT +3, время: 15:55.
