Старый 02.03.2021, 02:25   #1
powerobjects: Scribe Azure AD App Configuration
Источник: https://powerobjects.com/announcemen...configuration/
As of March 21, 2021, Microsoft is deprecating the “Online” authentication type for Microsoft Dynamics 365 / CRM for the Customer Engagement product. This means that if you are currently using Scribe Insight (scribe on-prem) to integrate with an online CRM Organization you will need to upgrade your scribe instance to 7.9.5, install the TIBCO Scribe® Insight Adapter for Microsoft Dynamics 365 And...
Source
msdynamicsworld: Azure Insights: Tags; Container images; Deploying AD Connect; App Service and Stack; IPv6 for VNets Blog bot DAX Blogs 0 02.03.2020 09:11
powerobjects: Using Azure KeyVault to Encrypt D365 for Finance & Operations Data Blog bot Dynamics CRM: Blogs 0 09.10.2018 02:23
powerobjects: Field Service Mobile App: Set up and Configuration for Dynamics 365 Online Blog bot Dynamics CRM: Blogs 0 16.01.2018 01:12
Часовой пояс GMT +3, время: 17:12.
