crmtipoftheday: Tip #1351: Flows not triggering after environment copy
Источник: https://crmtipoftheday.com/1351/flow...vironment-copy
============== Today’s tip from Ankita Chavan – a good reminder to get your housekeeping in order while copying the environments. Got a tip of your own? Send it to jar@crmtipoftheday.com! We were working on the full copy of data from UAT Environment to dev Environment and we were testing existing functionality. We found that flow was not triggering. We tried the following solutions:
Go to the https://admin.powerplatform.microsoft.com/ -> Select Environment -> Edit and Check the Administration Mode of the Environment. ![]() The Administration mode of the Environment should be disabled for the flows to run. If the administration mode is enabled, none of the Asynchronous Processes including Power Automate will get triggered. Источник: https://crmtipoftheday.com/1351/flow...vironment-copy
| Опции просмотра | |
