Доступен, правда если делать по видео при Start Exicution возникает ошибка...
X++: Unhandled Exception: System.IO.FileNotFoundException: "Microsoft.Xrm.Sdk, Version=9.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" . .
System.ModuleHandle.ResolveType(RuntimeModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type)
System.ModuleHandle.ResolveTypeHandleInternal(RuntimeModule module, Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments)
System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctor, Boolean& ctorHasParameters, Boolean& isVarArg)
System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes, Boolean isDecoratedTargetSecurityTransparent)
System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeAssembly assembly, RuntimeType caType)
PluginProfiler.Library.ProfilerUtility.GetProxyTypesAssembly(Assembly pluginAssembly)
PluginProfiler.Library.DeserializedProfilerReport..ctor(String serializedReport, Assembly pluginAssembly)
PluginProfiler.Library.ProfilerUtility.DeserializeProfilerReportInternal(String assemblyFilePath, String serializedReport)
PluginProfiler.Library.AppDomainProxy.InitializeProxy(String assemblyFilePath, String typeName, String logFilePath, String compressedreport)
PluginProfiler.Library.AppDomainProxy.CreateProxy(Type type, AppDomain domain, OperationConfiguration configuration, IList`1 trustedAssemblies, IList`1 partlyTrustedAssemblies)
PluginProfiler.Library.ProfilerExecutionEngine.Execute(ProfilerExecutionConfiguration configuration)
PluginProfiler.Library.ProfilerExecutionUtility.Execute(PluginPermissions permissions, ProfilerExecutionConfiguration configuration)
PluginProfiler.Library.ProfilerExecutionUtility.Execute(PluginPermissions permissions, OperationConfiguration operation, ProfilerReportingConfiguration reporting, CrmServiceClient administratorProxy, ITracingService tracing)
Microsoft.Crm.Tools.DebugPlugin.DebugPluginViewModel.btnExecutionClicked()При этом плагин рабочий, правда там задействуются ILМerge и SPKL, а в остальном плагин простейший. А ругается вообще на основную библиотеку Xrm.. UPD: Хотя я смотрю он тут 9.0.0.0 а PRT я использовал 8.2, попробую на 9 сейчас... Последний раз редактировалось ximik33rus; 03.04.2020 в 09:31. |
