Старый 11.09.2019, 17:02   #7
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
А этот фикс не пробовали ставить-запускать? Похоже на ваше описание
The On-hand entries aggregation by financial dimensions is introduced with KB 3007375 around December 2014. https://fix.lcs.dynamics.com/Issue/R...&bugId=2816224.
This is basically extending the previously mentioned cleanup tool by also cleaning up records which have field Closed set to True!
The reason why this is needed is basically because in certain scenarios, you might have no more quantities in InventSum for a certain combination of inventory dimensions, but there is still a value. In some cases, these values will disappear, but current design does allow values to remain from time to time.
ax 2012 r3, ax2012r3, performance, sp_whsonhand, sp_whsonhandwithdelta, whs, полезное, производительность
dynamicsaxse: March release – Dynamics AX 2012 R3 Blog bot DAX Blogs 3 24.07.2017 13:55
emeadaxsupport: How to slip-stream AX 2012 R3 Cu 8 Blog bot DAX Blogs 0 21.04.2015 11:11
emeadaxsupport: AX Content: Deploy AX 2012 R3 on Azure Blog bot DAX Blogs 0 12.05.2014 06:17
Часовой пояс GMT +3, время: 21:28.
