Старый 23.06.2019, 18:17   #1
axaptacorner: Saving last value on the form
Источник: http://axaptacorner.blogspot.com/201...e-on-form.html
We can save last value on the form in AX so that when next time form will open it will show last saved value in the certain control:
We will take example to save value of below mark control on inventory counting form:
Below are the steps to enable this functionality:
1. Add below code snippet in class declaration:
AllOpenPosted allOpenPostedTrans
#define.CurrentVersion(1)
#localmacro.CurrentList
allOpenPostedTrans
#endmacro
2. Add below methods on the InventJournalTable form:
//To save default value in case if no last value available
public void initParmDefault()
allOpenPostedTrans= AllOpenPosted::All;
//To convert object to container
public container pack()
return [#CurrentVersion, #CurrentList];
//To convert container to object
public boolean unpack(container _packedClass)
int version = RunBase::getVersion(_packedClass);
switch (version)
case #CurrentVersion:
[version, #CurrentList] = _packedClass;
return true;
default:
return false;
return false;
//To save last design name
public IdentifierName lastValueDesignName
return element.args().menuItemName();
//To save last value
public IdentifierName lastValueElementName
return this.name();
//To save valueType in this case Form
public UtilElementType lastValueType()
return UtilElementType::Form;
//To store User Id
public UserId lastValueUserId()
return curUserId();
//To save Legal entity details
public DataAreaId lastValueDataAreaId()
return curext();
3. Add below code in Run(above Super) and Close(last in method) form's method:
Run:
xSysLastValue::getLast(this);
AllOpenPosted.selection(allOpenPostedTrans );
Close:
allOpenPostedTrans = AllOpenPosted.selection();
xSysLastValue::saveLast(this);
Compile and open form change value in the "show " control and close form next time form will open with last value in the show field.
I hope this will help !!!!
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 05:42.
