crmtipoftheday: Tip #1246: Use “Get Record” to get all the fields in Flow
Источник: https://crmtipoftheday.com/1246/use-...ields-in-flow/
============== You create a Flow that runs when a record is updated. Occasionally the Flow fails on one or more step with a template error that reads something like the following: Unable to process template language expressions for action ‘Check_if_Last_Name_contains_data’ at line ‘1’ and column ‘1823’: ‘The template language expression ‘triggerBody()[‘lastname’]’ cannot be evaluated because property ‘lastname’ doesn’t exist. You think: of course the lastname property exists–it’s one of the standard fields and it is available to be selected from the field list. Not so fast–take a look at your failed flow and expand out the when a record is updated. You will notice that none of the fields that do not contain data (nulls) is included in the list. ![]() ![]() Cover photo by unsplash-logoBrian Taylor Источник: https://crmtipoftheday.com/1246/use-...ields-in-flow/
Опции просмотра | |
