Старый 22.09.2018, 18:14   #1
ax_mct is offline
ax_mct
Banned
2,548 / 1091 (0) ++++++++
Это не поможет так как нет чего-то смог из коробки печатает excel и работает на сервере
Тут интересный момент
В принципе можно
We are using windows service on a server that has Excel installed. That service is requested by Web Application from a different server, making the service render the document and save it on the shared file server where Web Application then grabs it.
The windows service uses COM object's functions to create an Excel instance and render xml structure of a document using a blank template, then save it using the COM functions save it in specific format.
this.m_Excel = new Application();
this.m_Excel.Visible = false;
this.m_Excel.ScreenUpdating = false;
this.m_Excel.DisplayAlerts = false;
this.m_Workbook = m_Excel.Workbooks.Add(BlankTempleteFilePath);
this.m_Sheet = (Worksheet)m_Workbook.Worksheets[1];
// blablabla, filling the document...
this.m_Workbook.ExportAsFixedFormat(XlFixedFormatType.xlTypePDF, resultPath, XlFixedForm
https://social.msdn.microsoft.com/Fo...forum=exceldev
Но не рекомендуется
Microsoft does not currently recommend, and does not support, Automation of Microsoft Office applications from any unattended, non-interactive client application or component (including ASP, ASP.NET, DCOM, and NT Services), because Office may exhibit unstable behavior and/or deadlock when Office is run in this environment.
http://support.microsoft.com/kb/257757/en-us
k3technical: Running an Electronic Report from a menu item Blog bot DAX Blogs 3 05.09.2017 15:37
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
sumitsaxfactor: Report Design and Controls Blog bot DAX Blogs 0 05.09.2012 22:11
ax-erp: Save SSRS report to pdf that uses Controller classes [Dynamics AX 2012] Blog bot DAX Blogs 0 19.07.2012 18:11
Часовой пояс GMT +3, время: 09:14.
