Старый 02.09.2018, 19:56   #1
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
How I Successfully Installed Dynamics 365 On Premise Finance and Operations
Dynamics 365 On Premise installation in a Step by Step Process which includes the Hardware Setup, Software Installations, LCS Connectivity and SQL Installations and Configurations. The Steps Provided below are based on Microsoft with more in details for everyone can Install Perspective
Hardware Layout:
The Below provided Hardware specification is for Optimum performance in the Production Environment.
Step 1: Plan your domain name and DNS zones
To Create or Plan your Domain .In the Server Domain go to àAdministrative ToolsàSelect Active Directory Domains and Trusts .Create a New Domain name as Local
Based on the Domain,Now plan the DNS Zones for ax and SF,In our example,it is
  • Ax.local.com
  • Sf.local.com
Step 2 :Plan your users and service accounts
Now the users has to be created in the Domain Machines based on the Purpose of the users to the applied applications
Step 3 :Create DNS zones and add A records
To Create the Dns Zones and A Records to browse the AOS Application and Service Fabric Clusture
As Planned in the Step 1 we need to Create the A records for ax.local.com and Sf.local.com
ADD DNS ZONE:
  1. Sign in to the domain controller machine , select Start, and start DNS Manager by typing dnsmgmt.msc and selecting the dnsmgmt (DNS) application.
  2. Right-click the domain controller name in the console tree, and then select New Zone > Next.
  3. Select Primary Zone.
  4. Leave the Store the zone in Active Directory (available only if the DNS Server is a writeable domain controller check box selected, and then select Next.
  5. Select To all DNS Servers running on Domain Controllers in this domain: Local.com, and then select Next.
  6. Select Forward Lookup Zone, and then select Next.
  7. Enter the zone name for your setup, and then select Next. For example, enter local.com.
  8. Select Do not allow dynamic updates, and then select Next.
  9. Select Finish.
Set up an A record for AOS
In the new DNS zone, create one A record that is named ax.local.com for eachService Fabric cluster node of the AOSNodeType type. Don't create A records for the other node types.
  1. Find the newly created zone under the Forward Lookup Zones folder in DNS Manager.
  2. Right-click the new zone, and then select New Host.
  3. Enter the name and IP address of the Service Fabric node. .
  4. Do not select either check box.
The same Procedure should be follow for remaining ax and SF
ax.local.com for 192.154.138.03
sf.local.com for 192.154.138.04
sf.local.com for 192.154.138.05
sf.local.com for 192.154.138.06
Step 4:Join VMs to the domain
  1. On the Start screen, type Control Panel, and then press ENTER.
  2. Navigate to System and Security, and then click System.
  3. Under Computer name, domain, and workgroup settings, click Change settings.
  4. On the Computer Name tab, click Change.
  5. Under Member of, click Domain, type the name of the domain that this computer will join, and then click OK.
  6. Click OK, and then restart the Server.
Step 5 Download setup scripts from LCS
  1. Sign in to LCS.
  2. On the dashboard, select the Shared asset library tile.
  3. On the Model tab, in the grid, select the Dynamics 365 for Operations on-premises - Deployment scripts row.
  4. Select Versions, and then download the latest version of the zip file for the scripts.
The Download will get a File with a Name Infrastructure Folder.
  1. Right-click the zip file, and then select Properties. In the dialog box, select the Unblock check box.
  2. Copy the zip file to the machine that will be used to execute the scripts.
  3. Unzip the files into a folder that is named infrastructure.
Step 6: Config Template file configuration:
Once the Infrastructure Folder is download, Copy the File in the C Drive.
  1. Update the Domain Name without .Com,.ae etc
  2. Update the users for the each purpose with your domain Name
  1. In the Second Session update the Certificate Subject Name and add the administrators group for the Domain
  2. Update the same for all the Certificates
  1. Update the VM Name and the IP Address of the VM
  2. It is very Important to have Fault Domain and Update domain Identical
Step 7: Service Accounts and User account Mapping:
Execute the scripts from the Script Folder.Navigate to the Infrastructure Folder and Run the script with powershell administrator Privileages
Script:
Run the below script to import users
Import-Module .\D365FO-OP\D365FO-OP.psd1
New-D365FOGMSAAccounts -ConfigurationFilePath .\ConfigTemplate.xml
Последний раз редактировалось sukhanchik; 02.09.2018 в 20:51.
d365fo, lbd
D365FO on-premises - опыт установки gl00mie DAX: Администрирование 56 09.12.2020 16:33
d365technext: SSRS Report with custom fonts in D365FO Blog bot DAX Blogs 0 15.08.2018 17:15
erconsult: Copy-paste with keyboard script 2: from Excel to D365FO Blog bot DAX Blogs 0 03.08.2018 11:12
instructorbrandon: Dynamics Operations On-Premise Tutorial Part 5A: Understanding the Azure Service Fabric Install for On Premise Blog bot DAX Blogs 0 10.08.2017 07:12
axsa: Power BI and Dynamics AX: Part 5: PowerBI.com and On Premise Data (Preview) Blog bot DAX Blogs 0 27.02.2015 15:11
Часовой пояс GMT +3, время: 18:16.
