d365technext: Card Pattern in Grid D365FO & AX 7
Источник: http://d365technext.blogspot.com/201...65fo-ax-7.html
============== Card Pattern in Grid D365FO & AX 7 Yesterday, One of my team member had task to show data in Grid in Card Style like work space, in the initial state we were trying to create work space tile dynamically but no luck. After spending hour i found an page with pattern design Card. Here are the some steps to achieve the below task. Step-1 Create Custom form and data-source and Grid, Step-2 apply the patter of list page on design node of the form and follow the design pattern instruction. Step-3 Now select the grid and change the following properties of Grid.
Step-4 Now add the Group in the grid and apply the pattern of business Card. Step-5 Follow the instruction of business card design pattern and add the required field. Step-6 Create Display menu item set object properties with you newly created form. Step-7 Create menu extension and drag the display menu item on it Step-8 Last steps to perform build and sync. Now login on you D365FO instance and verify the form... for me its working fine, kindly check the below screenshot for reference. Please feel free to contact me if you are facing any issue during implementation of this blog. Источник: http://d365technext.blogspot.com/201...65fo-ax-7.html
