Старый 04.07.2018, 17:15   #1
Logger is offline
Logger
3,987 / 3273 (117) ++++++++++
Записей в блоге: 2
Оставлю чтобы было.
Запускает 2 метода (текст ниже).
1-й с параметром RebuildIndexAll.
т.е. в базе модели запускаются хранимки
"exec [dbo].XU_Reindex"
"exec [dbo].XU_Shrink"
"exec [dbo].[XU_ResetHandleIdentity]"
// Microsoft.Dynamics.AX.Framework.Tools.ModelManagement.ModelStore
internal static void Optimize(SqlConnection connection, AxUtilContext context, OptimizeOption option)
	using (SqlCommand sqlCommand = ModelStore.CreateCommand(connection))
		switch (option)
		case OptimizeOption.DisableIndex:
			try
				sqlCommand.CommandType = CommandType.StoredProcedure;
				sqlCommand.CommandText = string.Format(CultureInfo.InvariantCulture, "[dbo].XU_DisableEnableNonClusteredIndexes", new object[0]);
				sqlCommand.Parameters.Add(new SqlParameter("@dbName", connection.Database));
				sqlCommand.Parameters.Add(new SqlParameter("@changeRecoveryModel", 'N'));
				sqlCommand.Parameters.Add(new SqlParameter("@mode", '1'));
				sqlCommand.ExecuteNonQuery();
				goto IL_246;
			catch (SqlException ex)
				context.ReportWarning(ex.Message);
				context.DisplayResult(string.Format(CultureInfo.CurrentCulture, Resources.DisableIndexFailure, new object[0]));
				goto IL_246;
			break;
		case OptimizeOption.RebuildIndex:
			break;
		case OptimizeOption.RebuildIndexAll:
			goto IL_184;
		default:
			goto IL_184;
		try
			sqlCommand.Parameters.Add(new SqlParameter("@changeRecoveryModel", 'Y'));
			sqlCommand.Parameters.Add(new SqlParameter("@mode", '2'));
			goto IL_246;
		catch (SqlException ex2)
			context.ReportWarning(ex2.Message);
			context.DisplayResult(string.Format(CultureInfo.CurrentCulture, Resources.EnableIndexFailure, new object[0]));
			goto IL_246;
		IL_184:
		context.DisplayResult(string.Format(CultureInfo.CurrentCulture, Resources.Reorganizing, new object[0]));
		try
			sqlCommand.CommandText = string.Format(CultureInfo.InvariantCulture, "exec [dbo].XU_Reindex", new object[0]);
		catch (SqlException ex3)
			context.ReportWarning(ex3.Message);
			context.DisplayResult(string.Format(CultureInfo.CurrentCulture, Resources.ReindexFailure, new object[0]));
		if (connection.State == ConnectionState.Open)
			try
				sqlCommand.CommandText = string.Format(CultureInfo.InvariantCulture, "exec [dbo].XU_Shrink", new object[0]);
			catch (SqlException ex4)
				context.ReportWarning(ex4.Message);
				context.DisplayResult(string.Format(CultureInfo.CurrentCulture, Resources.ShrinkFailed, new object[0]));
		IL_246:;
internal static void ResetHandleIdentity(SqlConnection connection)
		sqlCommand.CommandText = "[dbo].[XU_ResetHandleIdentity]";
Последний раз редактировалось Logger; 04.07.2018 в 17:18.
За это сообщение автора поблагодарили: gl00mie (5), vmoskalenko (1), AlGol (3).
ax2012, axutil, optimize, производительность
sjakalax: AxUtil and the application log Blog bot DAX Blogs 0 25.01.2012 23:11
Faulting application Ax32Serv.exe, version 5.0.1500.2985 Poleax DAX: Администрирование 10 30.11.2010 14:53
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
mazzy: Команда autoRun Blog bot DAX Blogs 6 05.01.2009 04:27
Вопрос по поводу "Модификации были отменены". Что можно сделать? Hans DAX: Программирование 23 22.12.2005 16:34
Часовой пояс GMT +3, время: 15:11.
