Старый 10.12.2017, 08:11   #1
How to create an AOT table field for a given Extended data type
Источник: http://alexvoy.blogspot.com/2017/12/...for-given.html
As you can see from the following code, we have to get the primitive or container type for a given EDT. It comes from method AOTtpeStr() as an abbreviation. Then you should call an appropriate method to create a new field.
private void createFieldInTableInAOT()
TreeNode treeNode = treenode::findNode(#ExtendedDataTypesPath);
TreeNode treeNodeEDT2extend = treeNode.AOTfindChild(edtType);
AOTTableFieldList fieldNode;
str typeStrCode = treeNodeEDT2extend.AOTtypeStr();
if(!treeNodeEDT2extend)
warning(funcName() + ".\n Extended data type "+ edtType + " not exists in AOT!");
return ;
switch (typeStrCode)
// string
case 'UTS':
treeNodeFields.addString(edtName);
break;
// real
case 'UTR':
treeNodeFields.addReal(edtName);
break;
// integer
case 'UTI':
treeNodeFields.addInteger(edtName);
break;
// int64
case 'UTW':
treeNodeFields.addInt64(edtName);
break;
// date
case 'UTD':
treeNodeFields.addDate(edtName);
break;
// time
case 'UTT':
treeNodeFields.addTime(edtName);
break;
// datetime
case 'UTZ':
treeNodeFields.addDateTime(edtName);
break;
// enum
case 'UTE':
treeNodeFields.addEnum(edtName);
break;
// container
case 'UTQ':
treeNodeFields.addContainer(edtName);
break;
// GUID
case 'UTG':
treeNodeFields.addGuid(edtName);
break;
default:
throw error(funcName());
fieldNode = treeNodeFields.AOTfindChild(edtName);
fieldNode.AOTsetProperty(#PropertyExtendeddatatype, edtType);
fieldNode.AOTsave();
currentFieldGroupTreeNode.AOTadd(edtName);
info(strfmt("Field '%1' of type '%2' created", edtName, edtType));
german_nav_developer: Upgrade Tips & Tricks Teil 3 Blog bot NAV: Blogs 0 17.03.2017 13:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
newdynamicsax: How do I access an extended table field from C#? Blog bot DAX Blogs 0 29.04.2016 02:18
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
ax-erp: How to Create a Primary Key for a Dynamics AX Table Blog bot DAX Blogs 0 18.12.2012 02:11
Часовой пояс GMT +3, время: 23:12.
