palleagermark: Important caveat with the "Chain of command" (CoC) feature
Источник: http://www.agermark.com/2017/09/impo...f-command.html
============== If you use CoC with the July 2017 application release, you need to compile and deploy the standard models you eventually use CoC with. The reason being that the standard models are compiled with Update 8 which didn't have CoC. This is a temporary inconvenience, and will not be necessary after the "Autum" release. So, if you write ISV/VAR solutions, you might want to postpone usage of CoC for anything you release before the "Autum" release. Источник: http://www.agermark.com/2017/09/impo...f-command.html
Сообщение от Blog bot
============== If you use CoC with the July 2017 application release, you need to compile and deploy the standard models you eventually use CoC with. The reason being that the standard models are compiled with Update 8 which didn't have CoC. This is a temporary inconvenience, and will not be necessary after the "Autum" release. So, if you write ISV/VAR solutions, you might want to postpone usage of CoC for anything you release before the "Autum" release. Источник: http://www.agermark.com/2017/09/impo...f-command.html |
| Теги |
| chain of command |
