Afna CRM: Executing SQL queries in CRM database on behalf of another user
Источник: http://a-crm.blogspot.com/2017/08/ex...-database.html
============== If you are using filtered views in SSMS it is not possible to see what data will be returned for other users. But there is a way! The GUID of the user is stored in the SQL CONTEXT_INFO. All you have to do is to run this piece of code: DECLARE @binUserGuid VARBINARY(128) DECLARE @userGuid UNIQUEIDENTIFIER SET @userGuid ='' SET @binUserGuid =CAST(@userGuid ASVARBINARY(128)) SETCONTEXT_INFO @binUserGuid From now on you will be able to query the data as if you would be logged in as another user. To clear the context info simply execute SETCONTEXT_INFO 0x I hope this helps those who are testing SQL queries for the CRM reports. Источник: http://a-crm.blogspot.com/2017/08/ex...-database.html
