Старый 16.08.2017, 14:23   #21
https://gist.github.com/mazzy-ax/4d4...7527623467aee8
class Tables
    public static void Main(Args _args)
        str aosServiceBin = 'C:\AOSService\webroot\bin';
        str packageDir = 'C:\AOSService\PackagesLocalDirectory';
        //or
        var environment = Microsoft.Dynamics.ApplicationPlatform.Environment.EnvironmentFactory::GetApplicationEnvironment();
        packageDir = environment.get_Aos().get_PackageDirectory();
        // it's kind of magic
        var runtimeProviderConfiguration = New Microsoft.Dynamics.AX.Metadata.Storage.Runtime.RuntimeProviderConfiguration(packageDir);
        var metadataProviderFactory =  New Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory();
        var provider = metadataProviderFactory.CreateRuntimeProvider(runtimeProviderConfiguration);
        // object names
        print provider.Tables.ListObjectsForModel('FleetManagement');
        print provider.Tables.ListObjectsForModel('FleetManagementExtension');
        print provider.TableExtensions.ListObjectsForModel('FleetManagement');
        print provider.TableExtensions.ListObjectsForModel('FleetManagementExtension');
        // single object by name
        var custTransMetaData = provider.Tables.Read('CustTrans');
https://gist.github.com/mazzy-ax/292...fc753bfca9c529
Код:
#Powershell
$aosServiceBin = 'C:\AOSService\webroot\bin'
$packageDir = 'C:\AOSService\PackagesLocalDirectory'
# or
add-type -path (Join-Path $aosServiceBin 'Microsoft.Dynamics.ApplicationPlatform.Environment.dll')
$environment = [Microsoft.Dynamics.ApplicationPlatform.Environment.EnvironmentFactory]::GetApplicationEnvironment()
$packageDir = $environment.get_Aos().get_PackageDirectory()
# it's kind of magic
add-type -path (Join-Path $aosServiceBin 'Microsoft.Dynamics.Ax.Metadata.Storage.dll')
$runtimeProviderConfiguration = New-Object Microsoft.Dynamics.AX.Metadata.Storage.Runtime.RuntimeProviderConfiguration $packageDir
$metadataProviderFactory =  New-Object Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory
$provider = $metadataProviderFactory.CreateRuntimeProvider($runtimeProviderConfiguration)
# object names
$provider.Tables.ListObjectsForModel('FleetManagement').count
$provider.Tables.ListObjectsForModel('FleetManagementExtension').count
$provider.TableExtensions.ListObjectsForModel('FleetManagement').count
$provider.TableExtensions.ListObjectsForModel('FleetManagementExtension').count
# single object by name
$provider.Tables.Read('CustTrans')
Последний раз редактировалось mazzy; 16.08.2017 в 14:41.
За это сообщение автора поблагодарили: trud (5), gl00mie (5).
ax2012, ax7, модель
Получить SQL-имя таблицы типа TempDB RVS DAX: Программирование 3 18.11.2014 11:50
Как получить Имя Амортизационной группы ОС (из модели учета НУ)? snow DAX: Программирование 2 09.08.2013 13:26
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
Как получить значения полей (modifiedDate, modifiedTime, modifiedBy и др.) при работе с объектами AOT типа Map? LRA DAX: База знаний и проекты 15 02.04.2007 13:37
SQL: Physical Address Extension (PAE). Recoilme DAX: Администрирование 3 20.04.2006 10:18
Часовой пояс GMT +3, время: 11:25.
