stoneridgesoftware: DIEF Issues: Discount Values Aren’t Importing Properly
Источник: https://stoneridgesoftware.com/dief-...ting-properly/
============== DIEF Issue: When we were trying to import sales and purchase lines with a discount amount or percentage tied to the Data Import Export Framework (DIEF), the values weren’t importing. If you look at the stage to target mapping, it’s a direct mapping so you would think yourself “Boy – this should work, why isn’t it bringing in the value?” DIEF Resolution: In reviewing the situation, what I found out is that it’s the sequence in which things happen that’s the problem. You probably don’t pay much attention to the “Sequence” in the “Map staging to target” form, but this is ultimately what was causing the issue. There is a function called generateDefaultSalesLineData() which has the sequence value of 3. Basically, the fields we are focused on are:
![]() NOTE: In later versions of AX 2012, this has been fixed. I believe the sequence number is 12. Источник: https://stoneridgesoftware.com/dief-...ting-properly/
