palleagermark: Resolve dll references for a project generated from a template
Источник: http://www.agermark.com/2017/04/reso...r-project.html
============== When you create a new project from a template, for example a new Best Practice Rules project, you might get a bunch of references that aren't resolved: To resolve these you can individually point each reference to the correct dll, or you can take the following faster approach. In Solution Explorer, right-click your project node and click Properties. The Project Designer appears: Select the Reference Paths page. In the Folder field, type the path of the folder that contains the items you want to reference, and then click the Add Folder button: The path for most D365fO dll's is J:\AosService\PackagesLocalDirectory\Bin\Click Save to save the setting and then close the dialog: And ... voilà: Источник: http://www.agermark.com/2017/04/reso...r-project.html
