Старый 05.02.2017, 15:12   #1
gustafwesterlund: Emailing Queues internally - OrgDBOrg to the rescue
Источник: http://gustafwesterlund.blogspot.com...gdborg-to.html
Using queues is in D365/CRM for managing functional email addresses is the the only way to go as
far as I know, unless you want to set it up as a full user, which I don't really see the point of.
I recently ran into an interesting issue with a customer pertaining to queues and that is when you want to be able to forward mails internally to users that are registered in D365/CRM. What happens is that with the standard setting you will get two emails. Hence, you might think that going into System settings and the email tab and unchecking the "Track emails sent between CRM users as two activities". However, this will have the unpleasant effect of disabling internal emails to queues, or in other words, if an internal user sends an email to a queue, to a system with this setting unchecked, D365/CRM will simply ignore the mail and not pull it into the D365/CRM.
By RRZE - Own work, CC BY-SA 3.0, Link
So, do we have to choose between duplicate emails for internal users and being able to send emails from internal users or not getting duplicates and no emails from internal users? Well, no, there is a very special set of settings to the rescue, OrgDBOrg, which are described here: https://support.microsoft.com/en-us/...t-dynamics-crm
There is a setting here called: DoNotIgnoreInternalEmailToQueues which by default is set to False. So, if you uncheck the "Track email sent between to activities" and then set this to True, the system will not ignore your internal emails.
A small word of caution, OrgDBOrg settings are fringe (but still supported) settings which hence are probable not as tested as normal settings in D365. I would hence recommend that you only use OrgDBOrg setting in the case you need very specifically them.
Gustaf Westerlund
MVP, Founder and CTO at CRM-konsulterna AB
www.crmkonsulterna.se
Microsoft Dynamics CRM Team Blog: Using Queues with Knowledge Management in Microsoft Dynamics CRM 2016 release Blog bot Dynamics CRM: Blogs 0 12.11.2015 23:13
gustafwesterlund: Queue question and the difference between community work and putting food on the table Blog bot Dynamics CRM: Blogs 0 14.08.2015 21:11
gustafwesterlund: Making CRM stick by using Dr. John Kotter 8 Step method - part 6 - Communicating the vision/Empowering Change Blog bot Dynamics CRM: Blogs 0 17.02.2015 03:21
Microsoft Dynamics CRM Team Blog: Introduction to Queues in Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 20.12.2010 22:11
dynamicsusers: More Message Queues Blog bot Dynamics CRM: Blogs 0 21.05.2008 01:25
Часовой пояс GMT +3, время: 12:23.
