Старый 04.11.2016, 20:14   #1
Kashperuk Ivan: Tutorial Link: Executing outbound work with pending demand replenishment work
Источник: http://kashperuk.blogspot.com/2016/1...ound-work.html
IntroductionIn Dynamics 365 for Operations we solved one of the long-standing complaints, where large work orders could not be started because of pending replenishment. A typical workaround then would be to artificially broke down the replenishment lines into a separate work order, so workers can do the picking for the majority of stuff. Then of course you'd get into problems with merging the
Kashperuk Ivan: Tutorial: Locations with open work exceptions in Microsoft Dynamics AX "7" Blog bot DAX Blogs 0 05.01.2016 16:12
Kashperuk Ivan: Tutorial: Custom work types and shipment notes on the mobile device in Warehouse management module in Dynamics AX 2012 R3 Blog bot DAX Blogs 0 01.07.2015 19:11
Kashperuk Ivan: Tutorial: Using Labor Standards in the new Warehouse Management solution Blog bot DAX Blogs 0 02.03.2015 18:12
Kashperuk Ivan: Tutorial: High level overview of entity statuses in the new Warehouse management solution Blog bot DAX Blogs 0 13.10.2014 15:11
Kashperuk Ivan: Walkthrough: Cancelling put-away work in Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 12.07.2014 12:11
Часовой пояс GMT +3, время: 01:06.
