Старый 01.10.2016, 04:15   #1
emeadaxsupport: How to use DIXF to import an Inventory counting journal into AX 2012 from an Excel source file
Источник: https://blogs.msdn.microsoft.com/axs...l-source-file/
I have recently worked with customers whom are using DIXF to import Inventory counting journals into AX 2012 as part of their monthly Inventory counts. As a result of this, I documented an example of how you can use DIXF to import an Inventory counting journal into AX 2012. NOTE:  In this example, the items... Read more
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Import Customers and Vendors in Dynamics AX 2012 Blog bot DAX Blogs 0 19.07.2013 15:11
DAX: How to gain additional value from the Microsoft application platform with Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 3 21.06.2013 15:16
emeadaxsupport: AX 2012 Retail: How to enable tracing in AX 2012 Retail Blog bot DAX Blogs 0 07.08.2012 15:11
emeadaxsupport: How to disable the Public Sector solution when using Microsoft Dynamics AX 2012 Feature Pack Blog bot DAX Blogs 0 07.08.2012 00:13
Часовой пояс GMT +3, время: 01:33.
