Старый 03.06.2010, 20:52   #1
For those that have not used this before, the Style Sheet Tool is a free code sample used as an addition to standard Dynamics NAV application, for enhancing send-to Word functionality on Dynamics NAV by allowing simple and user-friendly style sheet customization.
After lots of feedback form partners, we have added an extra dimension to this tool: the ability to export several tables with multiple records. Up to now, any number of tables was allowed provided they all show one record each, in addition to one table showing multiple records.
This ’constraint’ is now removed, or rather, the design is adjusted to allow several tables showing multiple records each, to be included in merge document design.
To align the tool with this extension, the following code needs to be replaced:
Codeunit 680 : Style Sheet Management
Global variables: add NoOfMultiLineTables and MLCounter
Name
DataType
Subtype
Length
XMLDoc
Automation
'Microsoft XML, v4.0'.DOMDocument40
MailMergeXMLDoc
Automation
AttributeArray
Text
250
GroupElement
Text
250
StyleSheetTemplateCode
Code
20
StyleSheetFunctions
Codeunit
Style Sheet Functions
Status
Dialog
InMultiLineSection
Boolean
NoOfMultiLineTables
Integer
MLCounter
Integer
ManageMultiLineChanges trigger
Old Code:
RemoveEndOfMultiLine(NodeTextValue);
EXIT(Return);
New Code:
// EXIT(Return); //changed line
CreateMultilLineSection trigger
Old Code:
// Create section for Multi-Lines
ChildNode := IOChildNode.parentNode;
New Code:
// Counter for multiple multiline sections //added line
MLCounter +=1; //added line
CreateMultiLineBody trigger
Local variables: the following local variable is added to the trigger
Name
DataType
MultilineEnd
Boolean
Old Code:
ParentNode := ChildNode.parentNode;
LoadAttributes(1,'name','multiline-section-properties');
AddElement(ParentNode,NewChildNode,Text043,1);
New Code:
// Add counter to multiline section name, for unique reference // added line
LoadAttributes(1,'name','multiline-section-properties'+FORMAT(MLCounter)); //changed line
Old Code:
ChildNodeList := ParentNode.childNodes;
FOR NodeCount := 1 TO ChildNodeList.length DO BEGIN
ChildNode := ChildNodeList.item(NodeCount - 1);
TempNodeName := ChildNode.nodeName;
IF TempNodeName = Text043 THEN
MultiLineNodeCount[1] := NodeCount;
TempNodeValue := GetTextNodeValue(ChildNode);
IF TempNodeValue <> '' THEN
MultiLineNodeCount[2] := NodeCount - 1;
END;
// If MULTILINE_END is not found then set end to number of nodes.
IF MultiLineNodeCount[2] = 0 THEN
MultiLineNodeCount[2] := NodeCount;
New Code:
NodeCount := 1; //added line
WHILE (NodeCount <= ChildNodeList.length) AND
(NOT MultilineEnd) DO BEGIN //changed line
// exit the loop when next multiline end is found //added line
IF TempNodeName = Text043 THEN BEGIN //changed line
END;
IF TempNodeValue <> '' THEN BEGIN //changed line
IF STRPOS(TempNodeValue,Text021) <> 0 THEN
MultilineEnd := TRUE; //added line
END; //added line
NodeCount +=1; //added line
END;
IF NodeCount <= ChildNodeList.length THEN
NodeCount := NodeCount -1; //added line
MultilineEnd := FALSE; //added line
RemoveEndOfMultiline Trigger
Old Code:
// Remove end node of Multi-Lines
ChildNodeList := XMLDoc.getElementsByTagName('w:r');
IF STRPOS(GetTextNodeValue(ChildNode),Text021) <> 0 THEN BEGIN
ParentNode.removeChild(ChildNode);
EXIT;
END;
END;
New Code:
// nodetextvalue = multiline_begin_tablename
NodeTextValue := COPYSTR(NodeTextValue,17,MAXSTRLEN(NodeTextValue)); //added line
//Check if this is the right MULTILINE_END to remove // added line
IF STRPOS(GetTextNodeValue(ChildNode),Text021+'_'+NodeTextValue) <>0 THEN //added line
// EXIT; // remove all ends //changed line
END;
END;
The extended codeunit 680 object is also attached.
Note: This extension works with both Style Sheet Tool 1.1 and Style Sheet Tool 2.0
You can direct your questions or feedback to jthunes@microsoft.com
Источник: http://feedproxy.google.com/~r/Micro...-extended.aspx
Часовой пояс GMT +3, время: 17:18.
