Старый 08.06.2009, 11:12   #1
yes is offline
yes
Нужен совет - хватит ли для SQL Server (используя для navision 4/0) сервера с следующей конфигурацией:
CPU - Intel Xeon 3.4 GHz (двухядерный)
Ram - 2GB
Исходя из кол-ва пользователей - 35.
Старый 10.06.2009, 19:39   #2
RedFox is offline
RedFox
Сообщение от yes Посмотреть сообщение
Ram - 2GB
Недавно видел документ, который показывает расчет Сервера в зависимости от пользовательской нагрузки. Сейчас нет возможности поискать.
Может старшие товарищи помогут???
Старый 29.06.2009, 19:17   #3
RedFox is offline
RedFox
Ram - 2GB
Нашёл ДОКУ. Hardware Guide for Dynamics – NAV называется. ТАм есть запись:
Sizing Formula for Dynamics – NAV clients and Windows Terminal Services†
10-15 Dynamics – NAV users per processor core depending on work load 64 MB of Memory per Dynamics – NAV user (assumes an object cache of 32 MB) 1 GB of Memory for the Operating System Internal SCSI or SAS RAID 1 10 – 15K RPM with 500 MB of disk space available for each user 1 Gigabit Ethernet connection † These recommendations assume that Microsoft Dynamics – NAV will be the only application running on under Windows Terminal Services. If Microsoft Office or other application will be deployed on Windows Terminal Services in addition to the Dynamics – NAV client the hardware recommendations will need to be taken into account in addition to those the Microsoft Dynamics – NAV client. Example 100 Dynamics – NAV users; CPU 100 users / 10 users per processor core = 10 cores†† or 100 users / 15 users per core = 6.67 cores which really equates to 8 cores††
For this example, a 4-way dual core or 2-way quad core server would be the recommended choice. Because Dynamics – NAV is utilizing client side cursors you may consider more smaller Terminal Servers for better network bandwidth such as 2 2-way dual core or 2 1-way quad core servers. RAM (100 users X 64 MB per user) + 1 GB for the OS = 7400 MB which equates to 8 GB of RAM For this example if you deployed a 4 way dual core server all 8 GB of RAM would installed on the that server and the same holds true the 2 way quad core machines. If you deploy multiple Terminal Servers the RAM calculation is a little different as we must figure in the 1 GB or RAM for the OS on each server. (50 users X 64 MB per user) + 1 GB for the OS = 4200 (4 or 6 GB of RAM)
In this example, you will need to take into account workload and activity to decide whether the 4 GB will be sufficient or you will need to scale up to 6 GB DISK 100 users X 500 MB per user = 50000 MB or 50 GB For this example we would recommend two internal 146 GB 15K RPM SCSI or SAS drives in a RAID 1 configuration to hold the Dynamics – NAV temp files, OS and program files, page file, and anything else installed on the Terminal Server. †† It is recommended that you use both calculations to find a feasible recommendation that can be applied to currently available hardware.
Если нужно по остальным деталям, таким как Storage, OS, Intel and AMD processors, Dual Core and Quad Core processors and Windows Terminal Services - пишите в личку
Часовой пояс GMT +3, время: 08:40.
