Старый 21.11.2008, 08:58   #6
DA_NEAL is offline
DA_NEAL
Аватар для DA_NEAL
788 / 54 (3) ++++
Примерно такой вот нужен код (сильно не бейте :-)). Фин. учет себестоимости должен быть по операциям.
DeleteConsumptionEntry(_ItemLedgEntryNo : BigInteger;_ShowMessage : Boolean)
ItemLedgEntry.RESET;
ItemLedgEntry.GET(_ItemLedgEntryNo);
IF ProdOrderLine.FINDFIRST THEN
REPEAT
ProdOrderLine."Cost is Adjusted" := FALSE;
ProdOrderLine.MODIFY;
Item.GET(ProdOrderLine."Item No.");
Item."Cost is Adjusted" := FALSE;
Item.MODIFY;
UNTIL ProdOrderLine.NEXT = 0;
ProdOrderLine.RESET;
ProdOrderLine.SETRANGE("Prod. Order No.",ItemLedgEntry."Prod. Order No.");
ItemApplEntry.RESET;
ItemApplEntry.SETRANGE("Item Ledger Entry No.",ItemLedgEntry."Entry No.");
IF ItemApplEntry.FINDFIRST THEN
REPEAT
AppliedFromItemLedgEntry.RESET;
IF AppliedFromItemLedgEntry.GET(ItemApplEntry."Inbound Item Entry No.") = TRUE THEN
BEGIN
AppliedFromItemLedgEntry."Remaining Quantity" := AppliedFromItemLedgEntry."Remaining Quantity" - ItemApplEntry.Quantity;
AppliedFromItemLedgEntry.Open := TRUE;
AppliedFromItemLedgEntry."Applied Entry to Adjust" := TRUE;
AppliedFromItemLedgEntry.MODIFY;
END;
ItemApplEntry.DELETE;
UNTIL ItemApplEntry.NEXT = 0;
LedgEntryDim.RESET;
LedgEntryDim.SETRANGE("Table ID",32);
LedgEntryDim.SETRANGE("Entry No.",ItemLedgEntry."Entry No.");
IF LedgEntryDim.FINDFIRST THEN
LedgEntryDim.DELETEALL;
ItemLedgEntry.DELETE;
ValueEntry.RESET;
ValueEntry.SETRANGE("Item Ledger Entry No.",_ItemLedgEntryNo);
IF ValueEntry.FINDFIRST THEN
REPEAT
GLEntry.RESET;
GLEntry.SETRANGE("Value Entry No.",ValueEntry."Entry No.");
IF GLEntry.FINDFIRST THEN
REPEAT
LedgEntryDim.RESET();
LedgEntryDim.SETRANGE("Table ID",17);
LedgEntryDim.SETRANGE("Entry No.",GLEntry."Entry No.");
GLEntry.DELETE;
UNTIL GLEntry.NEXT = 0;
LedgEntryDim.RESET;
LedgEntryDim.SETRANGE("Table ID",5802);
LedgEntryDim.SETRANGE("Entry No.",ValueEntry."Entry No.");
ValueEntry.DELETE;
UNTIL ValueEntry.NEXT = 0;
IF _ShowMessage THEN
MESSAGE('Изменено потребление в заказе ' + ProdOrderLine."Prod. Order No.");
Want to believe...
Часовой пояс GMT +3, время: 17:30.
