Старый 28.10.2008, 13:47   #1
RedFox is offline
RedFox
Сообщение от Красный Слон Посмотреть сообщение
Служба брандмауэра вообще выключена...
Тут вскрылся факт, что кроме переустановки системы еще переименовали центральный сервер и начались проблемы с сертификатами.
Извините, но так как мало времени пока могу предложить только такое.
Попробуйте проверить так ещё связь telnet Imya_Service_of_DD.
Если до четверга-пятницы не получится ничего - сообщите.
Error 12288 (0x3000) - Error Connecting to DD
Probable Cause - The Data Client cannot connect to the DD. Possible causes are:
1. The DD service is not running.
2. The Data Client is trying to connect to a service that does not exist or does not have a correct IP address associated with it.
3. The Data Client is trying to connect to the DD on a TCP/IP port that is invalid.
Resolution
Start the DD service and make sure it is running.
Make sure that the DD service name has an IP address associated to it. This can be checked by pinging the service name (Example : ping dd-ho). If the service name does not respond to a ping command, you need to reconfigure your DNS server or hosts files so that the service name points to the correct IP address.
The Data Client is trying to connect to the DD on a port that is not in use. If the DD is using a port other than the default listen port (16750), you need to make sure that this port is specified in the Services file on your computer and associated with the DD service name. However, if you use the default ports you do not have to specify anything in the Services file.
Часовой пояс GMT +3, время: 14:55.
