B
в†ђOlder revision Revision as of 17:11, 29 May 2008 Line 21: Line 21: ==B== ==B== {{top}} {{top}} + +'''[[Backup]] - a data set which is not a complete copy of the system (e.g. [[NAV database]]) but contains enough information to rebuilt it. '''[[The Beauty Of Simplicity|Beauty Of Simplicity, The]]''' - Original [[PC&C]] catch phrase for Navision. '''[[The Beauty Of Simplicity|Beauty Of Simplicity, The]]''' - Original [[PC&C]] catch phrase for Navision. Line 179: Line 181: '''[[Single instance codeunit]]''' - when run will create only one instance of it self on the client. That means that any other function that calls a Single Instance CodeUnit will see the same variables and data as any other task. '''[[Single instance codeunit]]''' - when run will create only one instance of it self on the client. That means that any other function that calls a Single Instance CodeUnit will see the same variables and data as any other task. + +'''[[Session]]''' - a connection between a [[Client]] and the [[Server]]. Sessions are counted as the number of client currently attached to the server. '''[[NAV_version_history#Product_Names|Solutions]]''' - Version 3.00 was initially given the name Navision Solutions. '''[[NAV_version_history#Product_Names|Solutions]]''' - Version 3.00 was initially given the name Navision Solutions. Источник http://wiki.dynamicsbook.com/index.p...e=NAV_glossary
Кто-нибудь в живую видел C/DART (упоминался по ссылке выше)?
