[Всем привет!
Возникла досадная ошибка. При нажатии на кнопку сохранить (в строках), которая находится на веб-части "заголовок - строка" для каждой строки, выходит ошибка: Цитата:
Server Error in '/' Application.
-------------------------------------------------------------------------------- Input string was not in a correct format. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.FormatException: Input string was not in a correct format. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [FormatException: Input string was not in a correct format.] System.Number.ParseDecimal(String s, NumberStyles style, NumberFormatInfo info) +0 System.Decimal.Parse(String s, NumberStyles style, IFormatProvider provider) +30 System.Convert.ToDecimal(String value, IFormatProvider provider) +63 Microsoft.Navision.EmployeePortal.WebPartLibrary.Utility.DecimalTools.GetDecimal ValueInvariantCulture(String decimalAsString) +75 Microsoft.Navision.EmployeePortal.WebPartLibrary.Utility.List.DataSetTools.GetDa taSectionForLine(BasePart webPart, DataSet ds, DataTable unmodifiedData, Boolean onlyFromDataSet, Int32 selectedLine) +711 Microsoft.Navision.EmployeePortal.WebPartLibrary.CombiPart.Action_Command(Object o, CommandEventArgs e) +3515 System.Web.UI.WebControls.LinkButton.OnCommand(CommandEventArgs e) +110 System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePo stBackEvent(String eventArgument) +115 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +18 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +138 System.Web.UI.Page.ProcessRequestMain() +1281 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:1.1.4322.918; ASP.NET Version:1.1.4322.919 Помогите пожалуйста. |
Маленькая просьба - пользуйтесь словарем, не засоряйте форум.
