emeadaxsupport: Crash or hang during AX Project or Report Build - Visual Studio 2013 / AX R3 CU8
Источник: http://blogs.msdn.com/b/axsupport/ar...ax-r3-cu8.aspx
============== Dynamics AX 2012 R3 CU8 now requires Visual Studio 2013. If you're experiencing a crash or hang when attempting to build projects, after installing CU8, please follow the steps outlined below. 1) Open your System Properties. (Right-click start menu, select System, then Advanced System Settings) ![]() 2) Click the Advanced tab 3) Click the Environment Variables button 4) Under the System Variables block, add the following value: a. Variable name = COMPLUS_LoaderOptimization b. Variable value = 1 5) Once the value has been loaded, restart the AOS service. 6) Close any instances of Visual Studio, re-open and attempt building another AX project or report. Источник: http://blogs.msdn.com/b/axsupport/ar...ax-r3-cu8.aspx
