emeadaxsupport: AX 2012 R3 - A user cannot synchronize to a Document Template Library with federated authentication and no error message displays.
Источник: http://blogs.msdn.com/b/axsupport/ar...-displays.aspx
============== Issue description: AX 2012 R3 - A user cannot sync to a Document Template Library with federated authentication and no error message displays,but If you are logged into SharePoint site and try attaching the file then, it works fine. Workaround suggestion: Setup is completed following the article below: Configure and use Microsoft Dynamics AX document management with Microsoft SharePoint document libraries [AX 2012] This a known issue and the logon prompt was remove when you are accessing the SharePoint Online through federated access. You need to logon to SharePoint online in a browser in order to generate the cookie cache and fix the synchronization issue. If you are not using federated authentication, where users have a direct connection to SharePoint Online, then Dynamics AX client will get a normal logon prompt, and complete a basic authentication over SSL. Writer: José Luis Alvarez Mesa <a href="mailto:jalvarez@microsoft.com"jalvarez@microsoft.com/a> Источник: http://blogs.msdn.com/b/axsupport/ar...-displays.aspx
