emeadaxsupport: AX for Retail: POS Training Mode
Источник: http://blogs.msdn.com/b/axsupport/ar...ning-mode.aspx
============== In Microsoft Dynamics AX for Retail EPOS, there is not a lot of documentation on training mode. Training mode can be used to test sales transactions and not record the transactions in Dynamics AX. The cash drawer will not open and credit card, debit card, check and cash transactions will not be processed. When POS is in training mode, the transactions that are created will have an Entry Status in the RetailTransactionTable with a value of 3 (Training) and the Transaction Status in the RetailTransactionSalesTrans will have a value of 3 (Training). When running the P Job, the transactions will be moved to Headquarters, but these transactions will not be affected when creating, calculating and posting a statement What you could do is create a POS Terminal in AX that is just a training terminal. You could then not sync this terminal back to Headquarters if you do not want to see the Training transactions in Headquarters. Note: You will not be able to activate training mode for MPOS or the Online Stores. Below are the settings to activate training mode in POS: Navigate to Retail > Common > Retail channels > Select your store > Miscellaneous fast tab Hide training mode should be unmarked. ![]() When you create a sales transaction, I like to add the Messages section to the layout so I know it is in training, but this is not necessary. Retail > Setup > POS > Screen layouts Click Designer button ![]() In Screen layout designer, click Design mode drop down and select Main layout ![]() In the Hidden Items tab, select Messages and drag to the layout. ![]() Position the field as you would like ![]() ![]() If you change the Store setting to not hide training mode, you must run the Channel configuration job to push this change to POS. If you change the POS layout, you must run the Registers job to push the change to POS. In POS, Activate training: When logging into POS, select the arrow next to the X button (lower right) and select Activate training ![]() You should see Training in the sign in window ![]() We added the messages field to the layout, so you can see POS is in training mode. ![]() When you tender the transaction, you should get a message that POS is in training mode ![]() To Deactivate Training mode once you are in Training mode, go back to the sign on screen and select the X again and Deactivate Training. ![]() Источник: http://blogs.msdn.com/b/axsupport/ar...ning-mode.aspx
