Старый 04.11.2014, 18:11   #1
emeadaxsupport: Inter-company goods trading (sales price equal to cost price) - Microsoft Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
The intercompany transactions are a common business practice where companies trading goods between each other. There is company sells the goods, and a company receives the goods.
The used documents in Microsoft Dynamics AX are sales order which used in the sender company which sells the goods, and the purchase order which used in Receiver Company which receives the goods. The trading of inter-companies may requires to keep the item cost consistent in the both companies and this requires a specific treatment in Microsoft Dynamics AX operations, and transactions executions.
The scenario assume that there are two sister companies; company A represents the company which purchase goods from an external vendor, and these goods are sold to its sister company B, these goods will be sold for an external customer the two sister companies are agreed that the sales and cost price of the intercompany transactions should be equal. Assume that the item cost in company A has changed after issuing the goods to the sister company B, by an extra charges (freight, transportation) and at the end of the month this changes will be reflected on the item cost after running the inventory recalculation/closing. This will be reflected on the intercompany-sales price on company A, and intercompany-purchase cost on company B.
In order to simulate this scenario on Microsoft Dynamics AX 2012 R3 we should have the master data, intercompany configurations, setups, and transaction execution.
In Microsoft Dynamics AX 2012 R3 client, go to the company which will represent the company which will sell the products (company A in our scenario). Go to Accounts Receivables| Common| Customers| All customers, and create a new customer represents the intercompany customer "company B". then go to General ribbon| Setup| Intercompany. In the Intercompany form mark Activate check box and identify the vendor account in the company B.
Then move to Sales order policies and Mark Unit price equal to cost price check box
Create an intercompany-sales order in the company A, then Microsoft Dynamics AX will create an intercompany purchase order in company B. The intercompany sales price is item the cost in the inventory, and the intercompany purchase order cost price equal to sales price.
At this stage the item cost is changed based on additional charges on company A, and this will be reflected on the intercompany sales order after running the recalculation/closing, then will be reflected on the intercompany purchase order. In case of the intercompany sales order is invoiced the cost changes will not be reflected on intercompany purchase order, neither the intercompany sales order.
Check also TechNet article Check intercompany order price discrepancies [AX 2012]
Thanks
Acknowledgment;
SueAnne MacRae Escalation Engineer
Valentinas Vaitkevicius Escalation Engineer
Slawomir Bronisz Escalation Engineer
Старый 05.11.2014, 09:03   #2
d&m is offline
d&m
MCT
Аватар для d&m
Manzana Group
459 / 186 (7) ++++++
Записей в блоге: 6
честно говоря, не понял зачем приравнивать Себестоимость к Цене?
первое закрытие/пересчет склада все равно равенство нарушат и дело не только в накладных расходах задним числом, а также в том, что на момент расхода - среднемгновенная себестоимость, на момент пересчета/закрытия себестоимость скорректируется согласно модели (ФИФО, средняя и т.д.).
Т.е. Себестоимость будет равна продаже строго до первого закрытия/пересчета... в чем смысл?
По нижней ссылке даже процедуру приделали, которая ищет разницу в ценах/скидках для пары Заказ / Закупка, НО, конечно, только для неразнесенных...
Как я понимаю, это продолжение танцев вокруг нерешенной (в Аксапте) проблемы исключения внутрихолдинговых оборотов и наценок (т.н. Intercompany elimination)...
И вместо внятного механизма исключения внутрихолдинговой наценки (как минимум для целей консолидированной отчетности) они предлагают продавать внутри холдинга вообще без наценки?
Sometimes there is a moment as you are awakening - when you become aware of the real world around you, - but you are still dreaming. - You may think you can fly but you do better not try.
Старый 05.11.2014, 19:36   #3
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Сообщение от d&m Посмотреть сообщение
Так точно. Глупость полнейшая.
Старый 06.11.2014, 10:49   #4
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Ну, судя по постановке, речь не про элиминирование, а просто "вот есть такая фича". На практике, действительно, очень специфично. Ну и в целом, в Аксе подход с себестоимостью очень много где упрощен. Взять хотя бы все сценарии с использованием себестоимости из карточки номенклатуры...
Для практики в РФ было бы наоборот интересно, чтобы после закрытия пересчитывались цены даже в разнесенных документах или хотя бы коррекции проводились.
Для некоторых "холдингов", кстати, приведенная в статье схема вполне подходит, если в ней возможно настроить доп. накладные расходы по продаже, включаемые в цену. Тогда классический вариант - перепродажи в течение периода (документы не разносим), закрываем склад, считаем себестоимость, делаем минимальную наценку - и постим документы.
Ivanhoe as is..
intercompany, себестоимость
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 15 Blog bot Dynamics CRM: Blogs 1 10.02.2016 10:26
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
emeadaxsupport: AX Content: Make Microsoft Dynamics AX 2012 yours! Blog bot DAX Blogs 0 01.10.2013 00:12
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
Часовой пояс GMT +3, время: 19:12.
