ax_gfm_framework_team: Dimension defaulting - Part 5 (Ledger dimension creation)
Источник: http://blogs.msdn.com/b/ax_gfm_frame...-creation.aspx
============== Introduction Continuing this series of blog posts, this post covers how default dimensions can be merged to create new ledger dimensions. This blog post series includes:
Default dimensions exist as a way to provide values that later will be used to create ledger account combinations used in journals and accounting distributions. Default dimensions provide the dimensions other than MainAccount needed for a ledger account combination, and can be combined with a default account, or another ledger dimension in order to produce one. As defined in the Ledger account combinations series of blog posts, a ledger account combination is just a set of MainAccount and dimension values with structure and order applied. As shown in Figure 1 above, choosing the Financials->Distribute amounts option from the purchase order line the accounting distributions form opens. It already has a ledger account combination defaulted “604250-00000001--Chicago-00000004”. From the previous blog post, the values for the Project, BusinessUnit and Department dimensions have been populated and a MainAccount defaulted from the posting item group on the item, as the Purchase expenditure for expense account for a purchase order as shown in Figure 2 below. ![]() ![]() Figure 2: Source of a default (main) account for the item on the purchase order line ![]() ![]() Figure 3: SQL query and results showing default account source The code required to merge the default dimension on the purchase order line with the default account from the item group is shown in Figure 4 below. Similar to merging default dimensions, once merged, a newledger account combination is created as shown in the query in Figure 5 below: In the next blog post, APIs used for most common defaulting pattern APIs will be described. Источник: http://blogs.msdn.com/b/ax_gfm_frame...-creation.aspx
