emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 7
Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-7.aspx
============== This is page 7 of 8 of the general performance analysis scripts online for the Performance Analyser 1.20 tool. See page 1 for the introduction. Use the links in the table below to navigate between pages. - General analysisAnalyse SQL ConfigurationPage 1Analyse SQL IndexesPage 2Analyse SQL QueriesPage 3Analyse BlockingPage 4Baseline - benchmark queriesPage 5- AX SpecificAnalyse AX ConfigurationPage 6Analyse AX IndexesPage 7Analyse AX QueriesPage 8Analyse AX Indexes INDEXES_IN_DB_NOT_IN_AOT INDEXES_WITH_RECVERSION -- -- INDEXES_IN_DB_NOT_IN_AOT -- -- -------------------------------------------------------------- -- Find INDEXES that are not defined in the AOT -- ----------------------------------------------------------------- SELECT * FROM INDEX_STATS_CURR_VW I WHERE INDEX_DESCRIPTION 'HEAP' AND INDEX_DESCRIPTION NOT LIKE '%FILTERED%' AND NOT EXISTS (SELECT * FROM AX_INDEX_DETAIL_CURR_VW A WHERE A.DATABASE_NAME = I.DATABASE_NAME AND A.TABLE_NAME = I.TABLE_NAME AND A.INDEX_NAME = I.INDEX_NAME) ORDER BY TABLE_NAME, INDEX_NAME -- -- INDEXES_WITH_RECVERSION -- -- -------------------------------------------------------------- -- Find INDEXES that have RECVERSION in the Key or Included list -- RECVERSION should NOT be apart of AX Indexes do to the -- frequency of updates ----------------------------------------------------------------- SELECT * FROM INDEX_STATS_CURR_VW I WHERE INDEX_KEYS LIKE '%RECVERSION%' OR INCLUDED_COLUMNS LIKE '%RECVERSION%' ORDER BY TABLE_NAME, INDEX_NAME . Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-7.aspx
