emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 8
Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-8.aspx
============== This is page 8 of 8 of the general performance analysis scripts online for the Performance Analyser 1.20 tool. See page 1 for the introduction. Use the links in the table below to navigate between pages. - General analysisAnalyse SQL ConfigurationPage 1Analyse SQL IndexesPage 2Analyse SQL QueriesPage 3Analyse BlockingPage 4Baseline - benchmark queriesPage 5- AX SpecificAnalyse AX ConfigurationPage 6Analyse AX IndexesPage 7Analyse AX QueriesPage 8Analyse AX Queries AX_LONG_RUNNING_QUERY_TRACE HIDDEN_SCANS_QUERIES OPTION_FAST_QUERIES USER_SCANS_QUERY -- -- AX_LONG_RUNNING_QUERY_TRACE -- -- -------------------------------------------------------------- -- Find long running queries from Dynamics AX with source code -- requires client tracing being enabled on the AOS configuration ---------------------------------------------------------------- SELECT TOP 100 [CREATED_DATETIME],[DATABASE_NAME],[ROW_NUM], [AX_USER_ID], [SQL_DURATION], [SQL_TEXT], [CALL_STACK], [TRACE_CATEGORY], [TRACE_EVENT_CODE], [TRACE_EVENT_DESC], [TRACE_EVENT_DETAILS], [CONNECTION_TYPE], [SQL_SESSION_ID], [AX_CONNECTION_ID], [IS_LOBS_INCLUDED], [IS_MORE_DATA_PENDING], [ROWS_AFFECTED], [ROW_SIZE], [ROWS_PER_FETCH], [IS_SELECTED_FOR_UPDATE], [IS_STARTED_WITHIN_TRANSACTION], [SQL_TYPE], [STATEMENT_ID], [STATEMENT_REUSE_COUNT], [DETAIL_TYPE], [STATS_TIME], [COMMENT] FROM [AX_SQLTRACE] ORDER BY [CREATED_DATETIME] DESC -- -- HIDDEN_SCANS_QUERIES -- -- -------------------------------------------------------------- -- Find Dynamics AX queries that only seek on DataAreaId -- NOT USEFUL for other products ----------------------------------------------------------------- SELECT TOP 100 * FROM HIDDEN_SCANS_CURR_VW ORDER BY TOTAL_ELAPSED_TIME DESC -- -- OPTION_FAST_QUERIES -- ------------------------------------------------------------------------- -- Find queries option(fast) set that have sort operations -- Dynamics AX only query -- -- Either we don't have an index to match the order by clause -- or the query is potentially to complex for SQL to pick that index -------------------------------------------------------------------------- SELECT TOP 100 * FROM QUERY_STATS_CURR_VW WHERE SQL_TEXT LIKE '%OPTION(FAST%' AND QUERY_PLAN_TEXT LIKE '%PhysicalOp="Sort"%' ORDER BY TOTAL_ELAPSED_TIME DESC -- -- USER_SCANS_QUERY -- -- -------------------------------------------------------------- -- Find Dynamics queries that are scanning ----------------------------------------------------------------- SELECT TOP 100 * FROM USER_SCANS_CURR_VW ORDER BY TOTAL_ELAPSED_TIME DESC Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-8.aspx
