axmfg: Product Configuration: Setting values based on system variables - example, current user ID
Источник: http://blogs.msdn.com/b/axmfg/archiv...t-user-id.aspx
============== In this blog post we will describe how you can set values based on the current user ID by leveraging system-defined table constraints together with the build-in query range methods. If you are familiar with the Product Builder configurator, you may by familiar with the User Profile feature where you can associate a collection of default values with a given user. Use the following description to achieve a similar behavior using the Product Configurator. ![]() Creating the System Table The table we create for this example should look like this and have two columns, that is, one for the User ID (uses the UserID EDT) and one for our user-specific value (an Integer to keep it simple). ![]() Once the table is created, we can add the user specific data. ![]() As seen above, we have added the value 42 for the Admin user ID. The intention is that when the table constraint is created and used in model, the attribute, which will be bound to the UserSpecificIntegerValue column, will be assigned the value that corresponds to the current user ID. Creating the Table Constraint Now that the System Table is created, we can create the actual table constraint. This is done by opening the Table constraint definition form, under Product information management -> Common -> Product configuration models. Create a new table constraint by clicking the new button. ![]() Select System defined, and enter the name of the table created previously. ![]() Add a column for the user-specific integer value and choose an integer attribute type with ranges. Now comes the part which gives the attribute a user-specific value. This can be accomplished by opening the Select query (SysQuery) form and entering the range specified below. The content of the table will be filtered to just return the records associated with the current user ID. ![]() Click OK to complete the table constraint creation, click Next in the Wizard, and then click OK again. Using the system-defined table constraint in a Product configuration model Having just created our system-defined table constraint, we are now ready to use it in a Product configuration model. Below I have create a very simple model with 3 attributes:
![]() Similarly, I have added an attribute named "Only Dmitry", which only will be visible if the user log on to Dynamics AX is associated with User ID Dmitry. ![]() Once the attributes have been defined, it's time to attach the table constraint to the model. This is done by creating a new constraint in the constraints section and selecting Table constraint in the opened dialog. Then select the new table constraint and associate the user-specific value attribute with the user-specific value column, as shown below. ![]() Launching the model and understanding the results We are now ready to launch the model we created with the attached table constraint. As can be seen below, once the model is loaded, the User Specific Value is assigned the value 42 by the configurator. The "Only Admin" attribute is shown and the"Only Dmitry" attribute is hidden. ![]() This example can be extended to include several other concepts like hiding subcomponents and grouping user specific value into table constraints. An obvious use case would be that you hide some parts of the Product configuration model from the order takers (Susan persona). This could be engineering-specific details and the product designer (Emil persona) would still be able to see them. Furthermore, the above pattern can be used together with other of the build-in query range methods.
Note: It you are running on a build that has a performance fix to run the XML generation in IL, you will need to generate IL for the SysQueryRangeUtil class. I hope you find this useful Источник: http://blogs.msdn.com/b/axmfg/archiv...t-user-id.aspx
| Опции просмотра | |
