Старый 01.12.2013, 23:15   #1
axStart: Printing PDF documents
Источник: http://www.axstart.com/printing-pdf-...-pdf-documents
I had some trouble generated PDF in AX 2012 last months. The issue is A4 paper size, but also printing in landscape. I start looking in AX, Visual studio; everything was fine, but the PDF documents still suXX. On the end I found a solution in SSRS and it was working.
So how did we do this. The answer is in the config files of the SSRS server. You have to search the internet on the bush word Rendering
http://technet.microsoft.com/en-us/l.../ee210530.aspx
If you have read this link, you will say ok, can someone give me just an copy with the config file adaptions. I don’t want to understand it as long it works. And we are lucky
http://www.bictt.com/blogs/bictt.php...er-pdf-in-a4-1
and here is a copy of my adaption.
PDF in A4 Landscape
PDF
8.27in
11.69in
PDF in A4 Portrait
PDF
11.69in
8.27in
The location of your adaption:
axStart: Microsoft Dynamics AX Diagnostic Framework (Beta) tool Blog bot DAX Blogs 0 22.03.2013 16:11
emeadaxsupport: AX for Retail: Printing Receipts with Windows Drivers Blog bot DAX Blogs 0 25.01.2012 10:11
Dynamics AX Sustained Engineering: Form 27A printing issues when printing to .pdf file format Blog bot DAX Blogs 0 17.06.2010 02:08
C# and AX Development: Printing directly to PDF in AX Blog bot DAX Blogs 0 18.03.2008 03:14
axStart: mailing a PDF attachment Blog bot DAX Blogs 0 23.01.2008 22:30
Часовой пояс GMT +3, время: 11:32.
